lekt player
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:uploaded MOD17
my best try to keep all bass! try test the bass. can be better. should be tighter more free bass. coz i mod the stack to work harder
i see you touched only DEP and stack/heap, good result. original file a bit imbalance, focus not good fixed. MOD17 better exeption organic: i think DEP, need set by compiler's commandline, will try DEP again.
remember v2.90.4 MOD or ?? later , very good MOD.
think can not MOD file structure by PE edit tools, they can leave many things needed changing. so then OS generation still does looking for removed elements, not found, no error, but SQ lesser.
you are right in some factors (section, DEP,...) but do this by PE edit tool give not 100% logical correct result.
i must try set in commandline and compiler make for 100% correct result.
feel stack/heap size MOD is best way. that's i think, not sure.
Re: lekt player
lekt wrote: remember v2.90.4 MOD or ?? later , very good MOD.
all earlier MODs use pkshan stack heap.
i feel that his mod is tuned for long duration note body, e.g. violin, vocal.
cannot handle fast notes with accuracy. agility is always lesser.
noind can handle difficult stack heap size better than c7.
coz better code?!
need more testing
Re: lekt player
lekt wrote: i see you touched only DEP and stack/heap, good result. original file a bit imbalance, focus not good fixed. MOD17 better exeption organic: i think DEP, need set by compiler's commandline, will try DEP again.
DEP = disabled -> sound is already very tight. if i tighten bass, then treble struggles. if i loosen bass, doesn't sound right. NO MOD is needed.
DEP = enabled -> sound is less tight, more easy. if i tighten bass, treble also better more ease.
better code can handle more tightening. e.g. noind can handle smaller commit size better than c7.
that's why i think DEP=enabled is better.
Re: lekt player
stack and heap is very powerful.
affect tempo, body duration, vibration, bass tightness, treble ease.....
now i only focus on tempo, bass tightness and treble ease.
Re: lekt player
noiman actually has something special. need more test
noiman is very CD sound. very smooth strong power. best opera vocal of all lekt
uploaded 2.99.9 256 noiman MOD15
cannot detect hardness. just sound perfectly clean and powerful and calm for opera female vocal.
noiman and c7 are brothers. noiman > c7. just more correct. emotion ~ same.
lekt wrote: in compiler if i use /DYNAMICBASE:NO then section .realloc removed (sound more clean but less organic). => try use this for MOD, coz OS generation will lookup .realloc section, not found and angry!!
retested DYNAMICBASE:NO. micro-texture has changed. think micro is lesser quality. need re-tune code.
Re: lekt player
heap size is so weird. large size distorts c7 tempo but improves noiman tempo.
maybe tempo was wrong got worse.
cannot use one mod for all versions
for most accurate piano body, stack commit size should be 16 bytes. no less no more. i don't know about other sizes
lekt
Re: lekt player
Post by lekt »
i tried with sizes in commandline, can not better than default. need try again.
uploaded:
v2.99.9 256 RTCc
v2.99.9 256 noRTCc
compare these compiling options. nortcc file size much lesser, reduced instructions in assemby code (i take machine code and assemby code by compiler, learning now). but SQ better or not.
Re: lekt player
uploaded lekt.exe2.99.9 256 noiman MOD19
MOD19 = MOD15 + new stack heap
tuned by piano correctness. didn't test jitter, hardness or anything else.
all things seem automatically better. noiman MOD19 is my new favorite
need to find ways to keep original bass hehe
reuploaded MOD19
Re: lekt player
lekt wrote:i tried with sizes in commandline, can not better than default. need try again.
uploaded:
v2.99.9 256 RTCc
v2.99.9 256 noRTCc
rtcc easily better. jitter/earaches is less.
tested piano. both correct. rtcc more calm and peaceful.
Re: lekt player
here noind MOD19 has the best "woman in love" vocal vibration.
must close everything, close console to see effect of new stack heap mod.
here 0.5ms + realtime will add ease to her vocal. unbelievable... after 2 months of tweaking. still 0.001% hard. need clean power for pc.
it is now 21st century.. need to listen taylor swift... her voice is easy to reproduce. even at peaks i can hear air/transparency just like real vocal
