Clive101 wrote:Hi
Just wondering if latest versions of MQn supports 24 bit only containers - ie play 16 bit wavs to a DAC that does only accepts everything in 24 bits?
Clive101
Clive
I think idealy you would like to have some switch, a bit like JPlay has, that indicates if you like to use high-res in 32-bit containers (24 in 32-bit container) or in native containers (so 16 in 16, 24 in 24) or forced 24 (both 16 and 24 in 24-bit containers)
That would cover the options I think.
The thing is I don't know if Gordon can support such a feature in MQn given the optimisations he does.
Can you Gordon?
sbgk wrote:there are 2 v1 control versions, is that with both ? the 200000 files need to be used together.
Neither work on the DiverterHR2/Thesycon combination for 32-bit containers.
sbgk wrote:
I can play hirez only with 200000 versions, so the control I am using is "mqncontrol.exe v1 2000000". It can play only one track, no issues any more as I experience with non 200000, but if I try 2 or more tracks, the second one will lead into continues static noise.
uploaded mqncontrol v2 200000 which should fix things
This v2 version also doesn't work on the DiverterHR2/Thesycon combination for 32-bit containers.
Clive101
Post by Clive101 »
Aleg wrote: Clive
Hi Aleg
Yes, that would be great but I was wondering if in fact 24 bit container support is more difficult to implement technically so hence why not implemented yet or just down to the fact that most DACS appear to process everything internally in 32bit, so not worth implementing?
Clive101 wrote:
Aleg wrote: Clive
Hi Aleg
Clive
No, I don't think so.
The current versions are using 24-bit containers for high res and the previous versions till 2.71 did support 32-bit containers for highres. So there is no issue supporting either form.
And treating 16-bit samples as 24-bit samples isn't more difficult, imo, than handling native 24-bit samples.
whats the 200000 mean
theres still some things i prefer in 2.73 448 for 16bit, i cant say 2.73 is better either
any chance of a hybrid?
John Dot
Post by John Dot »
With new MQn versions I can play: 16/44, 24/44, 24/48 but nothing above.
cvrle59
Post by cvrle59 »
nige2000 wrote:whats the 200000 mean
From Gordon's post (pg202)
"200000 refers to the period size in 100 ns ie 20ms which some devices seem to require"
cvrle59 wrote: From Gordon's post (pg202)
But some don't, so ....
What was 448 then
I'd like to test a tighter version
