cvrle59
Post by cvrle59 »
sbgk wrote:uploaded 200000 versions of control and play
It is getting better, but I still can't let you to retire, sorry.
24/96 - I can play one song in full now, but when it's supposed to start next one, only some kind of static noise.
16/44 - I can play the whole album, but when it switches between the tracks, you can hear a very short interval of that static, probably 1s long.
This could be matter of control program, I guess, or that is how is supposed to be as this version can go.
Thanks a lot for your effort!
Edit,
I just discovered that I can play 24/192 too with this version, but one track at the time only, same as 24/96.
Amazing, how some of my 24/192 sound with this new toy!
Hi Aleg,
When I paste your Batch file for the first time in my MQn 2,73 folder, I forgot to change the patway, but it sounded better than the previous Batch! More defined and punchy.
Then I remembered to change the patway (in the way that should be) and I got even more defined sound, but a bit to bright.
I played all 3 versions of the 2.73 (1.the regular; 2.the Tasker+ Batch with wrong patway and 3.the Tasker+ Batch with right patway).
Most of the times I like it better the one with the wrong patway!!! I know that it sounds crazy and does not make sense, but......
If you meant about the new versions, they play ONLY 16 bits. The last one what played 24 (I guess in 32 bits containers) where 2.71 versions.
Best,
Adam
sima66 wrote:Hi Aleg,
Best,
Adam
Hi Adam
Thanks, that confirms for me that Diverter/Thesycon combination is not supported yet for 24-bit playback.
I'm not quite sure yet what happened with the "wrong pathway" situation. I'll probably need to see it front of me the understand what's happening.
minionas
Post by minionas »
Arcam rDac (it wants all in 24bit conteiners) doesn't play any of 16bit material on any of recently posted mqn versions, though all of those plays 24bit (44 and 96khz).
Gordon
The wasapi-test for Diverter/Thesycon shows the following result:
EXCLUSIVE: off EVENT DRIVEN: off
192000 16 2 768000 4 1 0 - Format works ok
192000 16 2 768000 4 65534 22 16 3 - Format works ok
192000 24 2 1152000 6 1 0 - Format works ok
192000 24 2 1152000 6 65534 22 24 3 - Format works ok
192000 32 2 1536000 8 65534 22 24 3 - Format works ok
192000 32 2 1536000 8 1 0 - Format works ok
192000 32 2 1536000 8 65534 22 32 3 - Format works ok
192000 32 2 1536000 8 3 0 - Format works ok
EXCLUSIVE: on EVENT DRIVEN: off
44100 16 2 176400 4 1 0 - Format works ok
44100 16 2 176400 4 65534 22 16 3 - Format works ok
44100 32 2 352800 8 65534 22 24 3 - Format works ok
48000 16 2 192000 4 1 0 - Format works ok
48000 16 2 192000 4 65534 22 16 3 - Format works ok
48000 32 2 384000 8 65534 22 24 3 - Format works ok
88200 16 2 352800 4 1 0 - Format works ok
88200 16 2 352800 4 65534 22 16 3 - Format works ok
88200 32 2 705600 8 65534 22 24 3 - Format works ok
96000 16 2 384000 4 1 0 - Format works ok
96000 16 2 384000 4 65534 22 16 3 - Format works ok
96000 32 2 768000 8 65534 22 24 3 - Format works ok
EXCLUSIVE: off EVENT DRIVEN: on
EXCLUSIVE: on EVENT DRIVEN: on
So in Exclusive mode 16-bit samples in 16-bits container and 24-bit samples in 32-bits containers.
And in non-Exclusive mode 16-bit samples in 16-bit containers and 24-bit samples in either 24-bit or 32-bit containers.
Best,
Adam
Hi Adam
Bottom line is that I like the Tasker (with wrong or right pathway..;-)) and I highly recommend everyone to try.
Thank you Aleg, Taggart and thanks to Nigel for sending me the file folder.
EDIT: If anybody interested I can send the wrong pathway.......hehehehe!
Best,
Adam
With V3 and hires even I recognise the Supertweeters can't remain on.
Next thing to try and have a go at is Adam's hybrid version of tasker whatever that might be and the Aleg version.
From my brief reading on this I need to put lines into the MQN.Bat file!
uploaded mqnplay v4 24 bit for normal and 200000 versions
cvrle59
Post by cvrle59 »
sbgk wrote:uploaded mqnplay v4 24 bit for normal and 200000 versions
Is something wrong on my side, or V3/V4 still can't handle more than one track if hirez played with it?
All working fine here. Tried 4 tracks together awhile ago hires and seems grand no issues for me.
