probably the best usb to i2s device
wushuliu
Re: probably the best usb to i2s device
Post by wushuliu »
nige2000 wrote:Lifepo4 is key
And also a simple solution
Urge u to try them :)
Think i posted links to the clocks i used somewhere in the other thread
Its mostly the power supply to these clocks that does the magic
I ordered the 22/24 ndk clocks from diyinhk, the rest I can source from mouser or digikey I think.
I'm comfortable with mains voltage and dc power supplies but I don't have a lot of experience with batteries (for diy like this) and totally avoided the lifepo4 craze. I thought A123 were no longer available? I assume the ebay ones are fake. I'll do some research. For some reason I thought charging lifepo4 was complicated.
EDIT: It was randy's page. I saw his rat's nest of wires and said hell no, but I suppose I could take a much simpler approach : P
Hifime Es9038Pro
3eaudio TPA3251
randytsuch
Post by randytsuch »
rat's nest?? :)
I suppose that's true. Most of the wires are to bring power to each shift register, which does make a difference.
But you could use 4 wires for shift register power, and get 90-95% of the gain of lifepo4's.
And charging is easy, constant voltage so you just need a power supply that puts out the voltage you want.
Randy
wushuliu
Post by wushuliu »
randytsuch wrote:rat's nest?? :)
Randy
Heh. Thanks randy. I've found some lifepo sources so I'm leaning that way.
As for the constant voltage. Do I need a really good supply for charging or can one of those cheap generic lm317 with led voltage meter suffice?
Hifime Es9038Pro
3eaudio TPA3251
Randy
yea ive used prebuilt 317 supplies before with good success
randytsuch
nige2000 wrote:yea ive used prebuilt 317 supplies before with good success
Same. I actually use unregulated walwarts feeding a 317, seems to work fine. But I use a walwart with a transformer, not the new style cheapo ones that are all solid state and weigh like one ounce. lifepo4 batteries cover you sins.
And you can get "real" ones now, I plan to buy and replace the generics I used, one of these days.
Randy
wushuliu
Post by wushuliu »
Randy
I got some slightly larger green 2300Mah 'used' lifepo4 on ebay. Seemed legit.
http://www.ebay.com/itm/4pcs-A123-Syste ... 2482652073
Hifime Es9038Pro
3eaudio TPA3251
randytsuch
Looked like a good deal, took a chance and bought them too. lol
i use lifepo4 copys
no probs
wushuliu
Post by wushuliu »
randytsuch wrote:Looked like a good deal, took a chance and bought them too. lol
Sorry if this is a dumb question, but did you use two separate batteries to power the amanero and the sokeris isolated inputs, or one battery for both?
Hifime Es9038Pro
3eaudio TPA3251
randytsuch
I used one battery for both.
I removed the 5 to 3.3 reg from the amanero. Then provide 3.3V to both.
Randy
