Lossless SD digital Player is computer audio now reborn?
Re: Lossless SD digital Player is computer audio now reborn?
http://www.ebay.ie/itm/Finished-SD-loss ... 2078865774
http://www.aliexpress.com/item/Lossless ... 64497.html
Still waiting on mine to make its way to rural Mississippi... at least now the tracking number is indicating some progress in its journey.
Greg in Mississippi
Greg in Mississippi
I know that I work for a software house and so I would say this wouldn't I, BUT has anyone had a look at the software (aka firmware) that is driving the FPGA in this player and/or SDTrans?
nige is clearly going that extra mile on the hardware front, but that still leaves the software side as a possible limiting factor.
As we have found with MQn and now WTFPlay, the rendering code in the player can have a profound effect on SQ.
I expect the FPGA code is not available but those who have bought may be allowed.
Jonathan
Jonathan
That is the reason I went with the SDTrans.
But for all we know those who have no regard for IP may well have stolen the firmware from the SDtrans.
I think after Nigel finishes this thing I am sure it will be good. The question is was it worth the time?
Until someone in Ireland gets a SDTrans it will be a mystery as to whether it is as good, better, or ...
Sometimes that is the key to audio peace, not knowing those kinds of things. Sure works for me Half of the pleasure one gets from DIY is never hearing someone in the COMPONENT OF THE MONTH CLUB telling you there is something ever so slightly better available.
There is a fellow at AUDIO ASYLUM who says if the difference between two components is less than the difference in turning his head slightly sideways while listening he knows he does not need it. That is good advice.
modding this is relatively simple and fast its the dac thats trickyrickmcinnis wrote:That is the reason I went with the SDTrans.
im hoping pearse will caveUntil someone in Ireland gets a SDTrans it will be a mystery as to whether it is as good, better, or ...
i test with standard wire and long cabling for cost and ease if its better it will be much betterSometimes that is the key to audio peace, not knowing those kinds of things. Sure works for me Half of the pleasure one gets from DIY is never hearing someone in the COMPONENT OF THE MONTH CLUB telling you there is something ever so slightly better available.
software is a weak spot of mine im barely able to flash firmware on these chips nevermind programming
id doubt anyones going to provide source code it wouldnt make good business to release it
Is there not a way to get the code from a FPGA? Is it a one way door?
Did not think you were a coder!
Actually what made me think it might be available was this line in nige's £75 Chinese player in a box -
HOWEVER, that almost certainly is compiled executable not the source code. But thought I would ask.
Code for a FPGA is no different in concept from any other computer player code. Written in various languages and compiled to an executable which cannot be read.
Actually, it could make very good biz sense. If there was an ability to improve the code, then it could create an audiophile following much as the Soekris has.
Rick - the code for the SDTrans is very custom for that board. I doubt it even uses the same FPGA chip as nige's. So rest easy!
Jonathan
So that inferred they would supply firmware for updating.Under SD card with the firmware update function, we released Firmware APP.bin directory on the SD card, boot update, the update takes only 1-2 seconds, firmware deleted without deleting not affected.
Jonathan
It would not bother me if the SDTrans firmware could be stolen. I bet it would make the makers upset.
I am very happy I got what I did.
I have had more time to devote to other projects like the ripper which is essential.
What is lost there can never be got any other way ...
Got it where I think it is basically done - just bits and pieces to remove as time goes by. Now re-ripping everything.
Might just get those batteries installed this weekend along with the trick txcos.
But the sound I am hearing is so far beyond what I have had before I am not that motivated to make the change. I like to get bored with the system A LITTLE BIT before making a modification.
LMAOrickmcinnis wrote: But the sound I am hearing is so far beyond what I have had before I am not that motivated to make the change. I like to get bored with the system A LITTLE BIT before making a modification.
I'm the same way, I get lazy for a while and just listen, but then I want more better and start tweaking again.
think hes just gone down that river in egyptrandytsuch wrote:LMAOrickmcinnis wrote: But the sound I am hearing is so far beyond what I have had before I am not that motivated to make the change. I like to get bored with the system A LITTLE BIT before making a modification.
"this device is perfect in every way there is nothing i can do to improve it"
