nige2000 wrote:
<SNIP>
why is this board supposed to be good?
Nige,
My take...
1. Very simple processing in the FPGA, limited types of files, no data transformation, no reclocking, just take what is on the card and feed it out as an I2S signal, so minimal noise created in playback.
2. Good use of the hardware and board layout. The clocks are close to the FPGA, it only outputs I2S, this goes directly to the buffer chips for direct output, to an LVDS chip for the PS Audio HDMI output, and to an I2S->S/PDIF conversion chip (Cirrus, as I remember).
3. Reasonable distribution of power regulation right at the local consumers along with good filtering. It's a plus that you can power all of the sections separately for higher performance.
But it is basically just a digital turntable, no metadata, having your music only on SD cards, and some care has to be taken to keep from corrupting them (from the manual, don't turn off or eject the cards while they are being accessed). It is not as convenient or as flashy as most computer digital playback. I'm good with that, but am finding the process of loading SD cards a bit of a pain.
Greg in Mississippi
P.S. I got mine on the tail-end of the last GB, it was the base unit without the upgrade caps (on the picture of the back of the unit that has been posted) and no remote. It cost me about $350 USD, with the GB discount.
P.P.S. If you think all the battery powered stuff you guys do is viewed as crazy, take a look in the later posts in that thread on how they experimented with setting up a light-powered source for the SDTrans384... shine bright lights onto solar cells to power the unit!
