How do I begin?
HiFiFan
Re: How do I begin?
Post by HiFiFan »
That is a nice system to start. Similar to my early adventures. I can't remember the models but System Audio with Rotel amplification and an Arcam source and at the time I was very happy with it.
Re: How do I begin?
Yeah, I'd also be a fan of System Audio and they offer great value second-hand.
Adrian
Re: How do I begin?
Post by Adrian »
Yes... those Rotel Amps... they are one of the unsung heroes of Hi Fi, very reliable as well, they just don't break, keep going and going.
If I could justify spending a few hundred quid I would pick up that 1520 Rotel just to have it...perhaps as a stand by amplifier etc.
Unfortunately Budget is a bit tight at the moment... end of 2014 tax year, and money has to be offered up to the Tax man etc.
Re: How do I begin?
Can't comment on the Rotel but System Audio make a nice speaker. Danish, the finish is very good and they have a nice clean sound not clinical but definitely not loose and flabby on the bass. If you liked both components I am sure you could get a deal off Cloneys for both. That would leave a bit of budget for your dac.
You can then start saving for your expensive speaker cables and interconnects!
Re: How do I begin?
http://www.hifiwigwam.com/showthread.ph ... Ciunas-DAC
Maybe Nigel is right on me finding the bargains well at least an option worth thinking about. The stuff in Cloneys and this dac and you would be doing very nicely but maybe a bit over budget.
Re: How do I begin?
If you are just putting your toe in the waters then you could start with what a lot of us around here started with in our early ventures into PC based playback.....a JK DAC32 which takes USB in.
I have 4 different DAC's lying around that I need to list here some day but the JK DAC32 might ease you in and keep your main budget for speakers and Amp.
You can have it for €100 if you are interested.
Cheers, Pearse.
Re: How do I begin?
Christ, that's a good deal. Snap that one up tipdrinker!!
Re: How do I begin?
take arm and all with that offer
good luck find as good of value with the rest of the gear :)
panda2rom
Re: How do I begin?
Post by panda2rom »
Hi,
Like many said, you definitly should buy used loudspeakers.
Buy some that are high efficiency (the stuff in dB).
90dB or more would be good.
So then you can save ALOT of money on the amp.
quickly :
speakers A : 87 db.
Speaker B : 90 dB.
speakers A, max noise level, with a 100 W amp = speaker B with a 50 W amp.
You should buy the JK DAC32 DAC for 100 euros !
Pick a used cambridge audio 540a (for under 200 euros) or go for a tripath class T amp (100 to 200 euros brand new, even a 25W will do).
That leaves you with 700-800 euros for used speakers... that much can get you something good. Something really good.
Rob
Re: How do I begin?
Post by Rob »
Hi tipdrinker,
If you're not too fixed on the 1k price point, you should listen to a few music systems at different price points to decide what kind of sums you would be happy spending based on the improvements you would be getting. Since you're looking for something for the long haul, I would recommend starting in the midrange price bracket. The law of diminishing returns kicks in with the high-end, and you may find satisfaction without any strong upgrade-itis. There are also different ways to go with systems that give a greater sense of musicality or neutrality, which is a very subjective preference. You could try second-hand but be careful buying anything quite old as it may need work sooner rather than later.
