Intel server board S1200V3RPL
Re: Intel server board S1200V3RPL
elaprince wrote:Thanks
What would you recommend Nige for linear power supply??
Where you from ?
Is it 110 v or 220v?
How much plug and play is required or are you the diy type?
elaprince
Post by elaprince »
I am Adam friend
from Canada
Plug and play best but have a friend that might do it for me
Thanks Nige
elaprince wrote:I am Adam friend
from Canada
Thanks Nige
think i remember you at computeraudiophile when we were trying to get that audiophile windows to go working
seems like a very long time ago
canada is expensive for these type of things
im not sure if the intel boards work without power management so id be inclined to suggest either a teradak psu or leadex superflower 750w
or evga over with you
http://www.newegg.ca/Product/Product.as ... -_-Product
of course the teradak will be better
but the 750w smps atx supply will almost be as good as a pico with an excellent linear psu and its plug and play
elaprince
Post by elaprince »
elaprince wrote:http://www.amazon.ca/EVGA-SuperNOVA-Cer ... B00IKDETOW
This is OK or not really?
is ok
best/simplest std config
to better this supply it will involve a teradak and/or alot of diy electronics including batteries etc etc
elaprince
Post by elaprince »
Thank you
Which Teradak would you recommend? 350 or 250?
elaprince wrote:Thank you
It shouldn't matter a whole lot
But I have seen better dynamics with larger power supplies
You do realise there's no endpoint to this
elaprince
Post by elaprince »
Yes never ending journey lol
Thank you Nige
As far as ram goes any recommendations?
elaprince
Post by elaprince »
What do you think about Paul Pang dual rail PSU??
