Turntable Cartridges
Re: Listening Session - Dacs/CDPs
DaveF wrote:
I really wanted to upgrade my worn out cartridge to something better but now I'm going to have chuck my money at the Sony instead and also a new rack to house the system properly. The cart upgrade will have to be postponed.
I would be curious to know what your plan for eventually replacing that cartridge is: do you have something specific in mind as a replacement when you eventually get around to it?
I've shortlisted the following:
Sumiko Blue Point
Clearaudio MC Concept
Van Den Hul The One Special
Van Den Hul The Frog :-)
Re: Turntable Cartridges
Decided to move this from the DAC/CDP Listening Session thread to here
Sumiko Blue Point
Both of those Van Den Hul carts are supposed to be pretty special but The Frog is really really expensive coming in at over 2K.
I have a sumiko blue point 2 you can have an extended loan of. I don't think there's excessive miles on the clock but it's well used. It might cure that notion for a while!
Ivor wrote:I have a sumiko blue point 2 you can have an extended loan of. I don't think there's excessive miles on the clock but it's well used. It might cure that notion for a while!
Thanks Ivor, I might take you up on that offer.
Would you mind moving the last 2 posts here over to the Cartridges thread? Ta
On the phone right now so tricky, will have a look when on the pc.
Cheers Dave. I curently use the Sumiko Blue Point and cannot fault it. Mine is also coming to the end of its life so I am looking to replace it. I must do some research on the Van Den Hul cartridges that you have mentioned above.
[I've moved some posts from the CD and DAC thread.]
fergus wrote:Cheers Dave. I curently use the Sumiko Blue Point and cannot fault it. Mine is also coming to the end of its life so I am looking to replace it. I must do some research on the Van Den Hul cartridges that you have mentioned above.
I know that Noel Cloney highly regards the 'Van Den Hul The One Special'. Takes 2 weeks for it to be hand made. Not cheap though as it comes in at just under 1400 Euro but it does give a taste of what the serious high end carts from Van Den Hul do I'm told. The Clearaudio MC Concept is around 700Euro mark.
The only other thing I have to look at is that my phonostage is pretty a basic one from Pro-ject but I have something planned for that.
Thanks for that Dave. I know of the Van Den Hul cartidriges but I have never given them any consideration for some reason. I must do the necessary research and perhaps have a chat with Noel.
