Primaluna Prologue 2 Working on one channel
jaybee
Re: Primaluna Prologue 2 Working on one channel
Post by jaybee »
sounds yummy!
midland audio xchange have a puresound amp and a unison research(el34).There is a Jadis DA88S there if you really want to push the boat out.
jaybee
Post by jaybee »
While Jadis may be the ideal, I'm afraid trips to tile shops, carpet merchants, kitchen vendors, and a wall collapsing mean that the budget is limited for now!
jaybee wrote:While Jadis may be the ideal, I'm afraid trips to tile shops, carpet merchants, kitchen vendors, and a wall collapsing mean that the budget is limited for now!
Taking room treatment to the extreme Johnny!!
jaybee
Post by jaybee »
I wish!
Although the tentatively agreed hifi room has 4M ceilings, and is pretty close to the golden ratio, so the room should be good!
