lekt player
lekt
Re: lekt player
Post by lekt »
v2.97.6 160. not c3
Re: lekt player
maybe i should switch to win8 core
it has nothing. can delete powershell. no remote crap. no group policy. nothing.... nothing much to strip
only advantage of win2012 is you can delete/remove "device manager", and other things using dism.
win2012 has minimum metro.
win8 core has more metro... but everything else is less.
hmm....
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:1. install_wim_tweak.exe /o /l
2. notepad packages.txt
e.g.
install_wim_tweak.exe /o /c Adobe-Flash-For-Windows-Package~31bf3856ad364e35~amd64~~6.2.9200.16384 /r
be careful. delete wrong one = BLUE SCREEN = reinstall windows.
backup...
dangerous! hehe...
don't understand, if i need Adobe-Flash for browser then need keep its pakage?
Re: lekt player
e.g.
backup...
dangerous! hehe...
install_wim_tweak.exe does this:
1. makes a few permission changes in registry
2. now delete package is possible.
3. it calls microsoft's "dism .../remove-package..." to remove the package
or you can do it manually... takes more time.
if you need flash, don't delete... hehe
Re: lekt player
you use win8 pro? you have tones of crap! as much crap as win2012
for example i did this:
install_wim_tweak.exe /o /c Microsoft-Windows-Multilingual-Package-admin~31bf3856ad364e35~amd64~en-US~6.2.9200.16384 /r
your win8 should have this.
i remove tones of things. but they are server features. not exist in win8
Re: lekt player
i haven't even remove printing things
coz it broke notepad needs printing... wtf...
Re: lekt player
i also did this
install_wim_tweak.exe /o /c Microsoft-Windows-NetFx2-OC-Package~31bf3856ad364e35~amd64~en-US~6.2.9200.16384 /r
install_wim_tweak.exe /o /c Microsoft-Windows-NetFx2-OC-Package~31bf3856ad364e35~amd64~~6.2.9200.16384 /r
bye bye .net 2... useless... all things better
don't delete .net3... bass = fat.
Re: lekt player
also deleted all packages that is *PSH-Cmdlets*
powershell command pack... useless
if you delete other things, i cannot promise you safety hehe
lekt
Re: lekt player
Post by lekt »
even can not download, found fake links...
could you upload to your google drive. need learn and firstly try test only. if BSOD then ...
not ready for backup now, too much data on C:\
Re: lekt player
uploaded
seems ok... https://www.virustotal.com/ says no virus
SHA256: af52e0b4b68fd6767ba5ff6d395dfc6dde2eb4755f77e5ea66aac4419c63d93b
File name: install_wim_tweak.exe
Detection ratio: 0 / 55
Analysis date: 2014-08-28 19:45:37 UTC ( 3 weeks, 1 day ago )
