hpraw is technical best for woman in love! her voice is 99.5% vibrating. only 0.5% hard herelekt wrote:good sound. raw style, everything have good quantity.
lekt player
Re: lekt player
Re: lekt player
ok, this code structure of v2.99.6xx can make sound more ease. for going to hifi need use tricks of v2.98.12 sop xx, v2.99.4 c7xx. sop and c7 and all neared good versions used only 8-bit data type, JC.
i think Intel x64 not much helps make sound "hifi". all things need go back to most classic/basically technologue. when we disable something hi-tech no need for our low tech/power player in system, that's doesn't mean we are wrong. but system don't like this, and it restributes resource, and our result easy become bad.
will try by compromise method.
Re: lekt player
don't know what i did wrong...
now.. only delete 10 packages > delete 300 packages... damn it....
incorrect = no SQ....
back to some proper testing...
nocnt maybe better than hpraw.
misjudged earlier! nocnt is actually very soft with ease supported by good bass quantity.
prefer nocnt vocal. richer warmer
think if nocnt has more bass quantity, sound will be more soft, we will have a new style
Re: lekt player
my OS now also have issue, not stable. used reg cleaner tool and deleted something maybe needed. difficult for testing sound.
i feel v2.99.6xx sound stage larger than others, more air, details. can not concluse what is correct, what is not. like their live sound. good emotion but not like as c7, will learn more this sound.
Re: lekt player
lekt, s4 is surprisingly good with Phil Collins' "do you remember"
s4 has good bass. also, it can produce treble of his voice very well
now compare s4 to recent versions. the treble cannot reach higher enough -> weighty.
s4 has no issue here
(s8 cannot do it)
now testing "do you remember" with 2.4.3...
as always, 2.4.3 can play everything! treble is little lesser than s4
why is 2.4.3 so special... what is different
only just realise s4 treble reaches quite high while keeping sweetness+calmness. maybe best treble of lekt.
c7 can do it too! s4 has more calm+sweet treble
(s8 cannot do it)
Re: lekt player
finally, went through all packages... hundreds of them
only special one is .net2. once removed it, seems dynamic range treble improves. focus better. more ease.
need more testing... this package changes SQ too much.
95% packages don't do much. only affects more/less noise/micro/ease.
feels guilty removing .net2. but music seems SO SO SO good.
(sometimes i confuse fat=focus)
Re: lekt player
try this hehehe... my current best...
pay attention to every single detail. mean it
Re: lekt player
ok... stripped ~100 packages. seems ok.
retesting all versions... keeping these:
2.99.6 256 nocnt
2.99.6 256 hpraw
2.99.4 256 usbc //tweaking purposes...
2.99.4 256 c7 //maybe best piano. death metal. vocal. evironment. love this one.
2.99.1 256 c3 //strong mid + bass + simple vocal
2.98.14 160 ctlx1 c2 //tape/radio. bass ok. treble ok. all things ok.
2.98.12 256 sop ser //sound moment
2.98.1 256 a32 //Barbra Streisand now her voice is 99.9% vibrating here... (1 month ago hard hard hard voice)
2.97.2 160 //reference for 2.97x
2.90.7 256 //energy + gun n roses
2.90.4 256 //death metal fast drum
2.75.1 256 s4
2.4.3 352 MOD
2.99.6 256 nocnt
2.99.6 256 hpraw
2.75.1 256 s4
2.4.3 352 MOD
Re: lekt player
too good!!!
teel me pls. how can remove these pakages, will remove all things. your previous recommends about mouse,... i didn't make coz maybe not much benefit for compile. now no needed pakages have big quantity of files and space on disk, need remove. when windows is booting many things are concurrent with my startup compiling .bat file.
v2.99.6 256 nocnt very good air, cleaness. almost quantity.
sound and weighty and easy, interesting. will make more quality.
and include to your list v2.97.6 160. strong vocal, good energy, emotion. bass/drum also, hard/terrible/strong, good power. try it with Pink Floyd/Time.
Re: lekt player
this method is more easy than using registry+dism.lekt wrote:too good!!!
download install_wim_tweak.exe
1. install_wim_tweak.exe /o /l
2. notepad packages.txt
e.g.
install_wim_tweak.exe /o /c Adobe-Flash-For-Windows-Package~31bf3856ad364e35~amd64~~6.2.9200.16384 /r
be careful. delete wrong one = BLUE SCREEN = reinstall windows.
backup
yes, that mouse tweak is not good enough. am making it better.
did you lose bass quantity -> dry?
2.97.6 or 2.97.6 c3?lekt wrote: v2.99.6 256 nocnt very good air, cleaness. almost quantity.
sound and weighty and easy, intersting. will make more quality.
and include to your list v2.97.6 160. strong vocal, good energy, emotion. bass/drum also, hard/terrible, good power.
don't worry...
2.97.6 > 2.97.6 v2 and 2.97.6 v3
bass is good! sharp fast tight.
2.97.6 better. bass more free.
