lekt player
Re: lekt player
lekt wrote:in my case c11 clarity, treble > c7. balance much better.
c7 all things very good and correct, only balance have little issue. this balance makes sound sometime dirty a bit, reduce clarity. but c7 can be correctly in good tweaked OS, and using !.exe. not sure...
need more testing.
think dirty is correct?
impossible for win8/win2012 to be "clean"
usually software players that sound "clean", the reverb is much gone.
need slowly slowly reduce dirty. c7 already is less "dirty" than ctlx. and c7 is much better
lekt
Re: lekt player
Post by lekt »
ok, will try with mouse tweak.
only my compiling work run as startup, automatically, don't touch any thing. now maybe services and device drivers loading affect result.
as you said some "quantium" can be inserted into .exe file by compiler. what is this?
coz each time compiler makes different result from same code. need learn to disable this metadata.
Re: lekt player
lekt wrote:ok, will try with mouse tweak.
hehehe am no expert of compiler...
some compiler adds GUID for each new compile. or increment the version number
maybe just the metadata is different?
Re: lekt player
c7 has good reverb/echo
try some very old recordings, when TV is still black and white....
like Billie Holiday or some jazz music, it feels like i am there at the jazz club.
c11 lost that magic!
Re: lekt player
figured out a trick to strip windows hehe
in registry, set:
1.Visibility=1
2.DefVis=2
3.delete key "Owners "
now i can delete anything! e.g.
dism /online /remove-package /packagename:Adobe-Flash-For-Windows-Package~31bf3856ad364e35~amd64~~6.2.9200.16384
bye bye adobe flash!
took out another >200 things
don't try this at home. have had blue screen hehe...
the sound seems cleaner, has more ease.
delete 50 things -> cleaner, more ease
delete another 50 things -> more ease, seems details is lost, has glitches. actually, details was noise....
delete another 50 things -> sounds is becomes richer, more quality
... seems ok so far
lekt
Re: lekt player
Post by lekt »
hard to beat code of v2.99.4. many things have optimized, think good code for this method. c7 is really good, its bass vibration have good air.
uploaded:
v2.99.4 256 c12
v2.99.5 256 c1
v2.99.5 256 c2
used new method for v2.99.5, render loop better, more smart operation with memory address. but some statements outside of loop may affect sound. try test c1, c2. if they will work for you then will more optimize code. prefer c2, vibration now better, keep good emotion.
Re: lekt player
c12 many things better > c7. c12 has good elements from c11.
c12's stage width is wider, but little stretched, so has stage earaches
among 2.99.4x, prefer c7
2.99.5 c1 vs 2.99.5 c2
first impression prefer c2
2.99.5 c2 vs c7
c2 has some earache in stage, only little bit.
c2 is more refined, more sweet treble tune.
vocal texture... seems "smoothed" in c2? c7 has more vocal micro?
overall, they sound very similar here.
lekt
Re: lekt player
Post by lekt »
interesting, v2.99.5 code is difference, new method. but sound is similar as v2.99.4, c7.
i think v2.99.5 code better, still not optimized.
touched OS, something better, other thing worse. and now i can not restore back to when c7 compiled. forgot what services running while compiling c7.
its bass depth very nice, and something not understanded. although it have little balance defect but not easy beat it.
Re: lekt player
lekt wrote:...forgot what services running while compiling c7.
c7 maybe little bit weighty. i.e. vocal vibration moment is a bit watery, not very sharp.
i see c11 isn't weighty.
Re: lekt player
here c7 has just one more issue guitar gives a bit hard earaches.
as a comparison, ctlx1 c2 gives zero earaches.
here my setup c7 is best live sound. note correctness is one of best if not best already. it has hypnosis bass. sound has ease. c7 doesn't sound dirty at all if my pc is good mood. sounds just analog and right.
another ~600 packages to remove! shall see if c7 gets much better
sound definitely has more ease but just interesting that i don't know if i lost details or noise....
time will time... hehehe
