lekt player
goon-heaven
Re: lekt player
Post by goon-heaven »
lekt wrote:uploaded v2.99.1 256
nice improvement on vibration and agility - especially good on drum and bass
goon-heaven
Re: lekt player
... and hard to stop listening
Re: lekt player
got a copy of "Do You Remember" Phil Collins.
prefer
2.98.14 160 ctlx1 c2 //sounds just right. maybe only version can do it!
maybe 2.98.19 256 ser1
these two versions are most relax and easy for this song.
other versions have a sense of hurry. not enough ease and peace.
(very useful song can detect good version easily!)
lekt
Re: lekt player
Post by lekt »
"Do You Remember" Phil Collins have simple bass melody but played by good bass guitar and player. high required softness and depth and vibration.
uploaded:
v2.99.1.256 c3
v2.99.2 256 pre
v2.99.2 256 pre preloads data to buffer render loop. doesn't work for my onboard sound card, sand/clicks/pops. but i can hear its sound, seems better. maybe work for you.
v2.99.1.256 c3 more depth, feel better musicality.
Re: lekt player
2.99.1.256 c3 > 2.99.2 256 pre > 2.99.1 256
Re: lekt player
uploading 10.What Are You Trying To Do (Interlude).zip
very simple quiet song. vocal energy is at mid. emotion at mid+bass.
2.99.1 256 c3 is near perfection.
2.98.14 160 ctlx1 c2 has little more realism coz bass is more predominant (coz her voice has bass). its mid is weaker so emotion is less.
notice at the first 30 seconds, there is guitar.
the guitar should "zoom" forward. ctlx c2 is correct.
c3 doesn't "zoom".
overall, 2.99.1 256 c3 is best i heard for vocal type of mid + bass. combine of strong emotion and good realism.
"Do You Remember" is same result. c3 more emotion. ctlx more realism.
Re: lekt player
after copying lekt.exe and rename as !.exe, "Application Experience" service may start, this service distorts sound.
save this as bat file
net stop AeLookupSvc
run it after lekt player makes sound.
uploaded:
lektAlbum2.exe
stop.bat
(and source code)
copy all files to same folder as lekt.exe
stop.bat looks like as this:
PAUSE 5
Re: lekt player
ok... retested all versions, am keeping the below versions... please tell me if i have missed some good versions...
//still testing these....
2.99.2 256 pre
2.99.1 256 c3
2.99.1 256
2.98.19 256 ser1 //natural weight flow
2.98.19 256 noall //note body
2.98.18 256 acav //peak control
2.98.14 160 ctlx1 c2 //tape, vocal
2.98.1 256 a32 //piano+pianist balance
2.98 256 //piano+pianist balance
2.97.7 160 mb //drum+bass+mid
2.90.17 256 //drum+bass
2.90.7 256 //drum+organic
2.90.4 //HEAVY metal
2.93 160 //weird whisper
2.75.1 256 s4 //thin+rich
2.4.3 352 MOD //classic
Re: lekt player
think that 2.99.1 and 2.99.2 pre have drum speed/weight more stable than 2.99.1 c3.
goon-heaven
Re: lekt player
Help!
Had to re-install widows server 2012 essentials R2 eval.
But the VS redistributables in my install pack have created mscvr120_clr0400.dll rather than mscvr120.dll so I get an error trying to play lekt. No music.. sob.
How to fix? which VS redistributables should I be using?
