lekt player
Re: lekt player
retesting dmas vs man1... (PC has good mood at night)
dmas
morning has harshness is now much reduced at night...
man1
sound was slower. now is little bit faster...
close console + realtime helps
(restored 1 and only bad tweak for metro. woman in love vibrates more. NO NEED to tweak win2012 metro (already stripped by MS))
dmas
man1
Re: lekt player
all v2.98.19 xx technically good, no isues. bass quantity and softness/vibration correct. they kept sound heigh and movement like as v2.98.12 sop. no issues in their vibration level (dmas heigh seems lesser but can be ok with using !.exe).
i think most difficult is bass. if bass correct and ok then all things will be good. interesting, low frequency always is problem for equipments as speaker, amplifier. also for software player, data stream => sound signal => sound wave for endpoint... usually bass is wrong going to end.
now testing for musicality and emotion of v2.98.19 xx.
Re: lekt player
listening man1 and man2.... right now...
man2 reproduces the actual piano much better.
don't understand why it is little dry.
man1 maybe more mellow than norm. or "weighty" as you would say
Re: lekt player
uploaded:
v2.98.19 256 noall
v2.98.19 256 ser1
v2.98.19 256 ser2
tested in bad bad OS, they can "play music". noall have most clarity and directly sound.
you can test for piano. need very careful with classical piano sound. maybe can choose from these versions.
v2.98.19 256 noall
v2.98.19 256 ser1
v2.98.19 256 ser2
Re: lekt player
you've done a great job! you would make a great pianist.lekt wrote: you can test for piano. need very careful with classical piano sound. maybe can choose from these versions.
listen to classical music, is same as watching football. much of it is possible to normal human being. impressive and enjoyable.
all 3 noall, ser1 and ser2 are great piano. no issue in skills.
they differ in volume and listenability.
ser1 loud notes are loud enough.
noall seems restrained in volume.
i feel ser1 is naturaler than ser2, in the way it flows.
apart from that, they are equal in details in skills.
Re: lekt player
noall focuses on full body of notes but its weight is little restrained.
ser1 is lesser in body but its weight goes "all the way".
lekt, listen to ser1's weight, especially for vocal, Barbra Streisand, the decay goes all the way
first time i hear Barbra Streisand in full vibration!!
almost bright and not bright. near perfect vocal depth.
ok... ser1 seems slightly bright.
noall's body+ ser1's weight = perfect sound.
Re: lekt player
yes, near...jesuscheung wrote:...lekt, listen to ser1's weight, especially for vocal, Barbra Streisand, the decay goes all the way
almost bright and not bright. near perfect vocal depth...
need a bit more strong, depth. but keep this softness. this song have very analog sound, perfect recorded, only player is not perfect, hehe...
Re: lekt player
recommend shan services tweak... whatever service is deleted from his win7, pretty sure you can do the same for win8/win2012.
deleted 29 services so far...
(very tiring testing one after another... exhuasted... )
last night noall sound volume was restrained.
now is much more natural. richer with more ease more vibration
need to find out what else to delete hehehe
Re: lekt player
i see v2.98.19 256 ser2 sound is most free, no effect, no strain. its sound more raw. not sure it can give good emotion or not...
need more test. be careful with effect raised by intense, strain although they are little. piano sound very sensitive.
Re: lekt player
ok, could you show this method. delete in registry and what services?jesuscheung wrote:recommend shan services tweak... whatever service is deleted from his win7, pretty sure you can do the same for win8/win2012.
