Squeezelite v1.5-365, Copyright 2012-2014 Adrian Smith. See -t for license terms
Usage: squeezelite-win.exe [options]
-s <server>[:<port>] Connect to specified server, otherwise uses autodiscovery to find server
-o <output device> Specify output device, default "default", - = output to stdout
-l List output devices
-a <l> Specify Portaudio params to open output device, l = target latency in ms
-a <f> Specify sample format (16|24|32) of output file when using -o - to output samples to stdout (interleaved little endian only)
-b <stream>:<output> Specify internal Stream and Output buffer sizes in Kbytes
-c <codec1>,<codec2> Restrict codecs to those specified, otherwise load all available codecs; known codecs: flac,pcm,mp3,ogg,aac,wma,alac (mad,mpg for specific mp3 codec)
-d <log>=<level> Set logging level, logs: all|slimproto|stream|decode|output, level: info|debug|sdebug
-f <logfile> Write debug to logfile
-m <mac addr> Set mac address, format: ab
ef:12:34:56
-n <name> Set the player name
-N <filename> Store player name in filename to allow server defined name changes to be shared between servers (not suppored with -n)
-r <rates> Specify sample rates supported by device, enables output device to be off when squeezelite is started; rates = <maxrate> | <minrate>-<maxrate> | <rate1>,<rate2>,<rate3>
-R -u [params] Resample, params = <recipe>:<flags>:<attenuation>:<precision>:<passband_end>:<stopband_start>:<phase_response>,
recipe = (v|h|m|l|q)(L|I|M)(s) [E|X], E = exception - resample only if native rate not supported, X = async - resample to max rate for device, otherwise to max sync rate
flags = num in hex,
attenuation = attenuation in dB to apply (default is -1db if not explicitly set),
precision = number of bits precision (NB. HQ = 20. VHQ = 28),
passband_end = number in percent (0dB pt. bandwidth to preserve. nyquist = 100%),
stopband_start = number in percent (Aliasing/imaging control. > passband_end),
phase_response = 0-100 (0 = minimum / 50 = linear / 100 = maximum)
-t License terms
Build options: WIN PORTAUDIO WINEVENT RESAMPLE FFMPEG
