lekt player
Re: lekt player
lekt wrote:did'n you confuse version? think v2.98.13 256 nogr may not work for you and goon-heaven. ctlx must be work, no special setting. try again. take control of tweaks, hehe...
goon-heaven, v2.98.13 nogr works for you? if it works then will reconstruct code by new code model, better for render loop.
yes. am confused...
sop has better treble
ctlx has better bass
Re: lekt player
something happened ! ! ctlx doesn't make sound again... wtf
restart PC 3 times. working again! so random...
goon-heaven
Re: lekt player
Post by goon-heaven »
lekt wrote:goon-heaven, v2.98.13 nogr works for you? if it works then will reconstruct code by new code model, better for render loop.
Thank you for all these new versions - having difficulty keeping up..
v2.98.12 ctlx: plays very nice.
v2.98.12 sop: plays very nice.
v2.98.13 nogr: does not work for me
Need more time to decide between ctlx & sop. Both are excellent.
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:something happened ! ! ctlx doesn't make sound again... wtf
weird. has review ctlx's code, all things OK, not mistake. this ctlx setting is the same as v2.79.2, as sop and nogr.
nogr works for you, JC. if not then i can forget this method coz it also can't work for goon-heaven. there's removed GetBuffer() and ReleaseBuffer() statements in render loop, much benefit, as i said for sbgk. he tried and works, i think that, coz not feedback from his.
Re: lekt player
goon-heaven wrote: Thank you for all these new versions - having difficulty keeping up..
2.97.6 c3 is a good one
latest 2.98x is best
lekt wrote: weird. has review ctlx's code, all things OK, not mistake. this ctlx setting is the same as v2.79.2, as sop and nogr.
seems working again. keeping going with ctlx. i love the sound. ctlx earache is ~zero.
lol think my OS is better again!
copy registry settings from win7/win8 to win2012, SQ becomes better
DevManView is the best! it lets you disable things "device manager" won't allow. SQ better again !!!
sound is more more solid, less and less raw, earaches is less and less
shan
Re: lekt player
Post by shan »
jesuscheung依你的口味,搞隻森海hd540或hd540 gold聽聽吧
你玩弄這些軟件音效,都只是些失真
搞個好後端聽聽,你就知你現在玩的有多錯了
Re: lekt player
shan wrote:jesuscheung依你的口味,搞隻森海hd540或hd540 gold聽聽吧
你玩弄這些軟件音效,都只是些失真
+1
Re: lekt player
你玩弄這些軟件音效,都只是些失真
have thought about buying one of those phones from you haha
ok seems you right... got happy too fast.
now only disabling the spaceport driver... shall test this a few days.
goon-heaven
Re: lekt player
lekt wrote:nogr works for you, JC. if not then i can forget this method coz it also can't work for goon-heaven. there's removed GetBuffer() and ReleaseBuffer() statements in render loop, much benefit, as i said for sbgk. he tried and works, i think that, coz not feedback from his.
Hey JC - does nogr work for you on Server 2012 R2?
Hey Lekt
These versions v2.98.12 sop/ctlx are best yet! You can stop here...
Re: lekt player
Hey Lekt
nogr is no sound. no skip. no error/exception. just stuck.
i forgot which old version that also removes GetBuffer() and ReleaseBuffer()
if my memory is correct, that version makes distorted sound.
hey shan, you there? you got me confused here.
are you saying DevManView makes sound worse?
cannot even touch things like
ACPI Fan
Microsoft Streaming*
etc
been listening same earaches for 1 year. now earaches suddenly disappears. hard to believe this is a coincident...
