lekt player
goon-heaven
Re: lekt player
Post by goon-heaven »
lekt wrote:v2.98.12 256 SHR vibration > all others, only need reduce sound weight, a bit liquid in my case.
Yes. This is your best yet. Thank you.
Re: lekt player
lekt wrote:v2.99 160 is most potential, SQ < v2.98xx but many things more correct, musical notes correct.
agree
2.98.9 op -> a little bit bloated/3D -> clean
2.98.12 -> a little bit muddy -> liquid/dirty
maybe (2.98.9 + 2.98.12) / 2 for better long time listening
lekt
Re: lekt player
Post by lekt »
uploaded:
v2.98.12 c2
v2.98.12 ctlx
v2.98.12 sop
v2.98.13 nogr
prefer ctlx. try them.
can not post message from my laptop, maybe ???
Re: lekt player
lekt wrote:uploaded:
v2.98.12 c2
v2.98.12 ctlx
v2.98.12 sop
v2.98.13 nogr
sop > c2
c2 has hard treble here
ctlx vs sop
sop treble vibrates more. ctlx is sharper
2.98.13 nogr vs 2.98x
nogr has more power.
my first impression prefers sop.
ctlx suddenly won't play?! weird...
with ctlx kicked out of competition, now sop is a winner.
sop is new best in piano musicality.
now Vladimir Horowitz has flow. piano nuances are kept or better.
piano notes are more correct.
lekt
Re: lekt player
Post by lekt »
i use Personalize\Themes\High Contrast Black + No Sounds and adjust screen brightness to minimum dark. sound better, cleaner.
anyone tried this. maybe we need windows 95, hehe...
lekt
Re: lekt player
Post by lekt »
three last versions used wasapi setting as v2.79.2, i like this sound colour. need take read file method of v.79.2, JC, difficult transfer it to C, its musical notes have nice scale.
not careful tested, will listen via speakers.
jesuscheung wrote:...sop is new best in piano musicality.
yes, enjoing 08.Liszt - Consolation No.3 from CD1, very good flow, his playing nuances... piano notes have pressure good changing with tempo. clarity heared micro sound.
Re: lekt player
lekt wrote:i use Personalize\Themes\High Contrast Black + No Sounds and adjust screen brightness to minimum dark. sound better, cleaner.
me too! how did you know that! haha
my color balance is at left-most
and i use color "black"
Re: lekt player
when i do testing, i turn off "High Contrast Black"
because the sound is too refined. cannot detect issues. haha
Re: lekt player
sop is new best here...
color is good like 2.79.2.
musical notes are new best.
can play opera music elegantly.
let me test some rock music.
rock music is great as always...
style is different.
high energy
density sound is a piece of cake.
vibration is goood.
i like it!
ctlx won't play. why why why... it did play 1 song
lekt
Re: lekt player
Post by lekt »
did'n you confuse version? think v2.98.13 256 nogr may not work for you and goon-heaven. ctlx must be work, no special setting. try again. take control of tweaks, hehe...
goon-heaven, v2.98.13 nogr works for you? if it works then will reconstruct code by new code model, better for render loop.
