lekt player
Re: lekt player
goon-heaven wrote:....
589368024960
pointer of wasapi data buffer 2:
589368025984
pointer of app data memory:
589393690624
explains why I never win lottery
haha
intel makes best driver. SQ better again
Intel Rapid Storage Technology Version 13.2.4.1000 WHQL
install driver manually, select series 9 driver
(my board is actually series 7. doesn't matter)
Re: lekt player
2.99 is like 2.90x. highest energy. texture is clearly. rock and roll style.
2.98x is another style. can play wider range of musical notes. has little bit stronger mid. vocal texture less clearly.
love them both...
prefer 2.98.9 op > 2.98.9 > 2.98.9 c2...
2.98.10 a32
2.98.9 op
a32-> dirtier, more complex vibration
op-> cleaner, more simple vibration
prefer 2.98.9 op
2.98.9 op vs 2.99
difficult choice...
Re: lekt player
finally got this Vladimir Horowitz - Complete Recordings on Deutsche Grammophon (DGG 474 370-2)
1kB/s for days haha
listening Horowitz playing Polonaise...
godly skill.
at first i didn't like his noisy rough style of heavy notes. actually he intended that way... like solider matching.
loving it now
2.98.1 reproduces the heavy notes extremely well... (not tested other versions yet)
lekt
Re: lekt player
Post by lekt »
"Intel Rapid Storage Technology Version 13.2.4.1000 WHQL
install driver manually, select series 9 driver"
explain me how to install this v13.xx, i can not, can only v12.xx series 7.
lekt.exe v2.99 160 have potential, its sound very correct, used RAM type, read file function as v2.90.7. need optimize code for improving vibration.
prefer Horowitz plays Chopin Heroic Polonaise Op. 53 in A flat major (at the White House 1978), great heroic, revolution. great finger weight technical. and Rachmaninov Piano concerto no.3 with NYPO 1978, https://www.youtube.com/watch?v=D5mxU_7BTRA
get HD format of this concerto, JC. i think his live playing better than studio. love all things of his...
Re: lekt player
lekt wrote:"Intel Rapid Storage Technology Version 13.2.4.1000 WHQL
Device Manager ->
"Update Driver..." ->
"Browse my computer for driver software" ->
"Let me pick from a list of device..." ->
"Have Disk..." ->
"Browse..." ->
(in my case, go to below folder:)
e:\Downloads\intel_rst_13.2.4.1000\Drivers\x64
-> select "Intel(R) 9 Series Chipset Family SATA AHCI Controller"
-> Next
IN CASE IF YOU DON'T LIKE THIE SOUND,
click "Roll Back Driver" to restore back previous driver
(i use "Roll Back Driver" to a b compare SQ)
lekt
Re: lekt player
Post by lekt »
thank, will try. and show me link download if you remember.
uploaded:
v2.98.11 256 AND
v2.98.12 256 SHR
prefer v2.98.12 256 SHR used shift operator for counter, and structure block of loop a bit changed. sound much improved for all frequency ranges.
v2.98.11 256 AND softness lesser, but vocal have different emotion. not sure.
Re: lekt player
2.98.12 > 2.98.11. more refined micro
Re: lekt player
lekt wrote: prefer Horowitz plays Chopin Heroic Polonaise Op. 53 in A flat major (at the White House 1978), great heroic, revolution. great finger weight technical.
if you just drop your hand, it is always 9.8m/s/s. natural weight. free-fall
Horowitz can fake natural weight with finger weight control... godly skill
he does use arm+gravity weight, but mostly on slow heavy bass notes.
Re: lekt player
my OS better again!
now instruments have organic. have life. especially noticeable with 2.98x
instruments can dance. not stoned/still/dead.
in terms of organic:
2.98x > 2.97x > 2.99
lekt
Re: lekt player
Post by lekt »
v2.99 160 is most potential, SQ < v2.98xx but many things more correct, musical notes correct.
v2.98.12 256 SHR vibration > all others, only need reduce sound weight, a bit liquid in my case.
