lekt player
lekt
Re: lekt player
Post by lekt »
hehe... windows windows. i afraid touch it. 3 months once touch it.
v1 have most "non-3D" sound, simple soundstage and.. better. only its balance not good as others. like its good music flow. v3 SQ is best, need more listen to test emotion.
v2 not bad, JC, its sound heigh seem most correctly, balance better than v1. difficult concluse now.
Re: lekt player
lekt wrote:hehe... windows windows. i afraid touch it. 3 months once touch it.
i think 2.90.9 vibration is more refined.
when my computer is bad mood:
-v1 vibration has 'sand'
-v2/v3 are more refined
-2.90.9 is even better (only little bit)
v3 vibration is stronger than density
e.g. when music has drum+guitar+vocal. drum has more focus.
v2 density is stronger than vibration
e.g. when music has drum+guitar+vocal. guitar+vocal has more focus.
i think this is why v2 emotion > v3
Re: lekt player
lol... had a breakthrough in OS!
now only 0.3% doesn't vibrates
OS = 0.2% better!
this means.....
if lekt is x1 better
then mqn2.82 is x5 better
and xa is x0.5 better
mqn2.82 SQ potential is almost maximized.
mqn2.82 doesn't have much texture quality. cannot improve more
i can see lekt can vibrate a lot more!!!!
i think need 5-10 more correct tweak, and then lekt will vibrate nicely
xa needs another 20-50 tweaks... give up!! hehe
Re: lekt player
finally i think my OS vibrates! 2.90.9 is a piece of cake! try make bass tighter more hard hehehe
everything you do is correct!
only incorrect is my OS/bios
after making 100000 mistakes...
now i can tell if tweak is correct in 1-5 mins. accuracy is 7 out 10!
all things have a sweetspot in windows audio
just need to listen to micro-stability
everything better... vlc, mpc, youtube flash, html5, lekt, mqn, xa...
now only 0.1% hard... near end game!
Re: lekt player
mqn2.82 and mqn2.2 are so weird!
when i fix my OS from 3% hard to 1% hard....
all players more correctly soft....
when my OS is 0.3% hard....
most players softer....
only mqn2.82 and mqn2.2 bass is getting tighter better
now my 0S is only 0.1% hard
mqn2.82 and mqn2.2 bass is getting more more tight better
maybe same thing will happen for lekt? when i get to 0.01%...?!?!
mqn2.82 tune was wrong last year
few months ago... becomes evening tonality
recently.... almost sunny tunality
zero harshness.... mqn at its best!!!
only texture is constant... more or less the same... nothing impressive. just beautifully raw
Re: lekt player
jesuscheung wrote:....
not totally correct!
2.90.4 is tighter better also... when all other players are softer
(the bass tightening effect not as much as mqn2.2 or mqn2.82)
lekt
Re: lekt player
Post by lekt »
v2.90.4 and v2.90.9 have good sound heigh, that makes sound non-3D but not compressed. later versions balance better but a bit 3D.
uploaded v2.96.5 160
2 days learned sound with Dynamic Base setting, yes or no? now concluse: yes. sound better vibrates and more live. of course if use fixed memory address then need /DYNAMICBASE:NO. will come back.
try test 2.96.5, more soft, more vibration and i think more live sound. only suspect drum sound, maybe need more strong?
Re: lekt player
lekt wrote:v2.90.4 and v2.90.9 have good sound heigh, that makes sound non-3D but not compressed. later versions balance better but a bit 3D.
very very goood sound... need more testing... cannot detect obvious issues
yes... sometimes i feel little 3D earaches with 2.9x... nothing too bad...
i think 2.90 is the most non-3D.
remember you make 2.90.2 for better treble? 2.90.2 got more '3D' earaches
Re: lekt player
usually i have 3D earaches when lekt when treble is liquid/shinny
i think treble doesn't vibrate = 3D
Re: lekt player
2.96.5 seems like overall best...
huge vibration
all things ok
focus is goood
maybe this is a new reference version?
