jkeny wrote:Rick,
If running +/- 4V from 4 batteries (2 in series on each side) you are running them at below their minimum recommended voltage (2.7V) so it's a very sub-optimal setup & I would suspect that this will be a problem.
i can confirm this is a bad idea cells are
always unbalanced 3:1 for 4v
Charging at these voltages really means that you are not trickle charging the batteries - they will act as fully discharged & draw the max current that the charger can provide (these batteries can recharge at 20Amps if the charger can do this). This may or may not be a problem for the charger, depending on its thermal build?
can confirm that a cell at 2.5v will pull 500/600ma if float charged 3.3/3.4v 4 cells is over 2 amps
id prefer to see a 3 amp capability of ps
i think the battery charger yokes blast high voltage into the cells in cycles to quick charge/increase amperage
Furthermore, putting 4V into 2 (3.3V) batteries in series is a recipe for failure as it is not balancing the voltage to each battery so one battery. It may not be such a big problem as this is close enough to the battery's max voltage of 3.8V to not kill one of the batteries but I could see one dead battery in the series being the result of this scheme over a longer period of time. This is a difficult one to predict as when a battery imbalance starts, it becomes a cascading effect - it will take up less current & the other battery more until one or both die.
thing is were using the batteries as capacitors i have several in series battery packs on my pc and there all unbalanced and i really couldnt give a monkeys as long as they still filter the power and dont leak etc
but its certainly not the way to charge batteries, but thats irrelevant as were using them as caps
I've said all this to Nige & he disagrees with me on some of this as his experience suggests that a batteries in series work fine in this sort of config. That may well be the case because the current drawn (& therefore current fed from charger) is so small that a battery imbalance isn't happening to a large extent or it may be that he is lucky & his batteries are well matched to start with? Or it may be that he has a dead cell in there already? A dead cell in a series will not be seen when the series is being constantly charged.
there very well could be dead cells but as long as there still filtering im cool with it
and for testing purposes which is the bulk of what i do
it doesnt bother me
if there ever is a final build ill try power each cell from a separate winding
Sorry, Nige, hope you don't mind me writing this (I've said most of it to you already) but I just feel that batteries in series with trickle charging is a wrong config when no balancing circuitry is used & my experience with balancing circuitry (at least the ones I've tried) have a detrimental effect on the clean power that these batteries provide.
i concur balancing circuitry i tested was a waste of time
That's why I suggested to Nige that using +/- 3.3V for DAM vref is probably better & to suck it & see. I too predicted a small drop in volume but it appears this isn't audible. Neither is it audible going up to 5V (he has tried this) so I don't know what's happening here. I know he reported 6V as audibly a bit strained but this may be for other reasons.
finding 3.3v worked was an accident when i had the supercaps in coz it took 6 mins to charge and we had sound at 2v and when i bypassed the 4v regs i was able to turn down the voltage to 3.3v
there wasnt any easily noticeable loss in sq 4v vs 3.3v as it took a while to charge or discharge there was nothing for it only to build another dac at 3.3v for fast ab tests which i still cant differentiate
i think you suggested 6.6v for higher output
i knew when i hit 5v we were heading the wrong direction strained/distorted
