sima66 wrote:
I don't know how the other versions after the first 448 sound, but this 2.72 (no rel) what I can play, it's the best thing I ever heard! Relaxed and detailed with the best middle range. Simple amazing!!!
yes, it sounds very good, just a bit bass light.
uploaded
mqnplay.exe 2.72 448 mem rel get + raw background
gone back to non rel version, this is the same as the above version, but smoother and better bass. playing a Stanley Clarke album and you would think I've got a tube amp.
am trying to do a 24 bit version, but have a slight hiccup with it at the moment.
Thanks Gordon downloaded that anyway so played first time. Very airy. Browsed through my music folder and somehow ended up playing Boney M 'gotta go home' as the first test track! Moved to Miles flamingo sketches and this sounds very good.Mellow airy just need to give it a good listen and compare it to other versions.
tony wrote:Thanks Gordon downloaded that anyway so played first time. Very airy. Browsed through my music folder and somehow ended up playing Boney M 'gotta go home' as the first test track! Moved to Miles flamingo sketches and this sounds very good.Mellow airy just need to give it a good listen and compare it to other versions.
Also uploaded another version that has a bit more energy, just by moving the position of one instruction in the render loop. Initially discounted this one, but sounds ok.
mqnplay.exe 2.72 448 mem rel + get raw background
Should I try these new once on my system, or they still won't work?
can you try playpcmwin and see if it plays with 448 samples/10ms buffer setting, can't think what else the issue is apart from buffer size.
gone back to mqnplay.exe 2.72 448 mem rel get + raw background, nice sound
cvrle59 wrote:"can you try playpcmwin and see if it plays with 448 samples/10ms buffer setting, can't think what else the issue is apart from buffer size.
gone back to mqnplay.exe 2.72 448 mem rel get + raw background, nice sound"
Non of these two new work. I downloaded playpcmwin, but I can't find those parameters you listed?
Ok I tried Output Latency 10ms, and it was very similar like MQNplay, I changed to 20ms and it worked...
Even 11ms will do it. I just monitored my Dac, and buffer will cross 10ms from time to time. It seems to be that 10ms is just on the edge. I hope this tells you something.
Glad you got it going. the rel get + raw background is excellent. Immediately like it. Not 100% sure about the other one it seems to feather lite but
hate making judgements quickly.
