sbgk wrote:uploaded a 448 10ms version that uses the assembly code
2.72 448 movdqa rel raw background and a non rel one.
Sounds pretty good, good to get the benefit of all the testing that went on with the assembly code.
makes the previous version sound clunky, don't know why I thought it was thin sounding, does my hearing change that much day to day.
Gordon
The rel versions all give crackling, static noise through the music.
Only the non-rel versions play OK.
Continue comparing the 448 non-rel versions to the 1024 which was still my favourite.
Aleg,
there is a non rel version there, it's just the way your sp/dif convertor/dac handles the data.
The rel version has the data preloaded and I think sounds the best as the data is passed to the device as soon as possible after the fill buffer event is called, some devices can't handle it though.
Which 1024 version was your favourite ?
I find the 448 version has fantastic midrange.
Gordon
This rel-issue, is that a thing of the ddc drivers or a thing of the actual ddc hardware? My Sonicweld DDC uses Thesycon drivers, but they are still the Windows 7 stuff because Josh from Sonicweld hasn't released his Windows 8 versions yet. So I just wondered if I should push him again, but now with a more acute reason.
The 2.71 raw background 8 + get normal is my favourite 1024. It has a good sense of space and detail and just that little extra depth jn the lower bass. I love it, it is my benchmark.
Aleg wrote:Gordon
don't think it is a driver version issue, just the it works.
so the non rel version works ok ?
shall listen to the 1024 again.
mjock3
Post by mjock3 »
sbgk wrote:
mjock3 wrote:I have R2, jriver, jplay, mqn, totalcmd, and drivers. That's it.
jrmc wasapi work ?
wasapi is not a listed option in my jrmc
mjock3
Post by mjock3 »
Aleg wrote:
mjock3 wrote:
mjock3 wrote:Still won't play.
Went to the R1 looked in task manager and it shows both mqncontrol &mqnplay in background processes. The taskmanager in R2 only shows the mqncontrol in the background processes.
Does anyone have any ideas on this?
Thank you,
Mark
Anyone able to help me with this issue?? Please..
Mark
Did you read this reply to your question by Nigel?
nige2000 wrote:No wasapi in core mode
minimal server mode is ok
Yes, that is when a did a fresh install. I am now running minimum server.
mjock3
Post by mjock3 »
jrmc wasapi work ?
I set the wasapi in Jplay and it is playing there.
mjock3 wrote:
jrmc wasapi work ?
don't know if you have to stop the jplay server first as it grabs the audio device and mqn can't initiate it.
sbgk wrote:
Aleg wrote:Gordon
the 1024 version doesn't do it for me.
mjock3 wrote:
jrmc wasapi work ?
In your mqn-directory do you have an mqnplay.exe file? So, one that has been renamed from its distribution name that doesn't end with .exe?
Do you have mqnload installed or do you use the mqn.bat directly?
If you have mqnload installed, kill the mqndeamon in the taskmanager, delete the mqnload directory from \users\administrator\appdata\local and run it anew from the mqn-directory and select an mqnplay-version you like to try, inside the mqnload-app.
If you use mqn.bat directly, does the cd-command inside the bat-file point to the right mqn-directory?
If all is in its proper place and pointing to the right directories it should just run.
