lekt player
Re: lekt player
i check and check my service tweak. seems correct.
except for RemoteRegistry
lekt, does your win8 have RemoteRegistry=disabled?
Re: lekt player
what RemoteRegistry key in RegEdit tool? what full path key?jesuscheung wrote:i check and check my service tweak. seems correct.
Re: lekt player
open serviceslekt wrote:what RemoteRegistry key in RegEdit tool? what full path key?jesuscheung wrote:i check and check my service tweak. seems correct.
look for Remote Registry
thx
Re: lekt player
Remote Registry: disabled.
try disable it.
try disable it.
Re: lekt player
yes. disable is better.lekt wrote:Remote Registry: disabled.
try disable it.
i think win8 has correct settings for audio.
win2012 is different. not as good.
Re: lekt player
new asio4all is out!
"After more than 4 years, of course, this is a *major* update! "
http://www.asio4all.com/
testing it right now..
some earaches are gone..
focus is better
sound seems more tight and mellow is kept
this thing has potential!
focus is better
Re: lekt player
made 10 changes in OS... sound is much softer + more texture.
now 2.90.4 drum weight improves to 99.5%. only little bit earaches. very tight bass + very high quantity vibration.
if i can make OS more soft, i think the earaches will disappear
2.90.9 is still more hard than norm... let me see i can make it better.
mqn.exe2.2 already is ok soft. but its bass isn't too tight. so soft sound is easy.
Re: lekt player
things are going well haha
realtime + timerresolution 0.5ms
all things improve.
softer sound.
tighter bass.
focus better.
more vibration.
refinement better.
tested with s4, 2.4.3, 2.90.9, 2.90.4. all better... no intense no strain haha
my OS finally has some quality. still far behind pkshan win7. need much better texture quality. i think hard/soft is big issue
all things improve.
softer sound.
tighter bass.
focus better.
more vibration.
refinement better.
Re: lekt player
uploaded:
v2.92 256 fibo
v2.92.1 256 fibo
used win8pro with VS2013 ultimate (i think win8.1 + vs2013 will be better, need install win8.1)
cuting data buffer by fibonacci ratio gives good sound, reduced latency.
v2.92.1 have good balance (now balance better than v2.4.3 ?), so all 3 frequency ranges have good focus, analog sound. the first time lekt player can play analog sound as Barbra Streisand/Woman in Love. try test this song, JC, its bass and treble very difficult reproduce by digital players.
v2.92 256 fibo
v2.92.1 256 fibo
Re: lekt player
listening 2.92...lekt wrote:uploaded:
v2.92 256 fibo
v2.92.1 256 fibo
yes yes.. lovely sound!
vibration quantity less than 2.90x, but sound is more engaging
zero hardness. analog softness
don't have Barbra Streisand... testing with Vanessa Paradis...
very very good vocal. better than 2.90x
constant background crackling... same as crackling like car radio going into tunnel or parking...
now listening to 2.92.1
same sound. more solid.
more crackling with 2.92.1!!!
vocal may need a little more weight... maybe crackling is distorting the weight
excellent versions
