yes. same here. 2.90.15 is on dry side. also thin. because thin, so 0.5% nervous.lekt wrote:not correct sound usualy:
clean <-> hard/dry
dirty <-> soft/wet
need soft/wet but in cleaness, otherwise sound will be dirty, not detailed.
feel v2.90.15 is clean but dry, little. here's not enough vibration (and micro vibration) in its cleaness. so need keep its clean/hard/dry and improve vibration/micro vibration. so then sound will be more soft/wet.
reason: not good balancing as v2.4.3.
will try as i think. not easy, hehe...
right now for me, best sound for me is 2.90.4. soft. clean. highest quantity in vibration.
2nd best = 2.90.9
3rd best = 2.4.3 MOD, s4, rax no zi MOD, mqn.exe2.2 MOD
win7+xa1080a = most delicate vocal + highest quantity texture in vocal.
king of vocal. not as analog as lekt or mqn. maybe intel C++, sse make less analog.
my 2012 only makes analog vocal. no quality in texture.
