Guess tthe LP
Re: Guess tthe LP
Number 2....
Re: Guess tthe LP
And he's back.
Well done cybot..
Re: Guess tthe LP
cybot wrote:Fair dues to you for keeping this alive....
Number 1
Excellent detective work on that one Dermot!!
Re: Guess tthe LP
Thanks lads, it's feels great to be back :-))))
Re: Guess tthe LP
ImageC&N sang on this album?
Image Pioneers of the New Wave of British Heavy Metal?
Re: Guess tthe LP
Only for the clue....
Number 5
Re: Guess tthe LP
The final piece in the jig saw.....and the easiest one! How did I miss it????
By the way John, how are you getting on with the Floyd reissues?
Re: Guess tthe LP
Well done Cybot,
I knew the Iron Maiden would be hard,but I thought there were a few metal heads around for that one.
So it's back to the drawing board for me...
Re: Guess tthe LP
jadarin wrote:Well done Cybot,
Thanks John. You mustn't have seen my query about the Floyd reissues; how are you getting on with them and which one(s) would you wholeheartedly recommend?
Re: Guess tthe LP
Hi Cybot,
I missed that one.
I'm enjoying the Floyd remasters overall.James Guthrie has done a great job on cleaning up the recordings,without messing around with the mix t
much.Roger water bass lines have a lot more weight and the sound quality of Dave Gilmour's guitar at times is simply stunning.
The soundstage and seperation is also excellent especially on meddle,wish you were here,animals.More is cleaned up ok compared to the original,but that wouldn't
be to hard as i think it was one of their weaker captured recordings anyway.
Wish you were here is the one that stands out at the moment...Brilliantly remastered and a massive soundstage.
I can't believe how dark Animals sounds and way more dynamic then I can remember.
Overall I think it's worth investing in a few of your favourites.
