lekt player
lekt
Re: lekt player
Post by lekt »
i've tried some days with different compiler settings, not sure in result. compiler also is difficult thing for sound adjustment.
uploaded:
lekt.exe1644 v2.87.2 1024
lekt.exe1644 v1.17 1024 (in folder v1 (1 FILE))
JC, could you test these 2 versions, have pops in your case or not. in my case pops..., much pops.
v2.87.2 use 1.5MB RAM, v1.17 new method reading file.
try them.
Re: lekt player
lekt wrote:i've tried some days with different compiler settings, not sure in result. compiler also is difficult thing for sound adjustment.
uploaded:
try them.
no pop
Re: lekt player
2.87.2 much improves on micro detail. clean.
2.87.2 > 2.87.
2.87 > 2.86.
stage seems stable.
1.17 mellower/warmer.
relisten s8. think it has cleanest very refined micro-vibrations.
lekt
Re: lekt player
Post by lekt »
s8, s4 are best of 2 files model. s4 have very rich sound, high SQ, will back to it, 2 files can give more potential coz isolate process better than isolate thread, lesser negative affect to sound.
v2.87.2 have good sound texture, details.
JC, i have transfered all things to C, and compiled to C-native. bulded 2 versions with more simple code, running with 2 threads. ah, C syntax take many my time, few days working with debug, now running, hehe...
uploaded:
v2.88 1024
v2.88.1 1024
now will make more complex code, can make sound better with C, only syntax, bugs... assembler later, need more learning.
Re: lekt player
lekt wrote:s8, s4 are best of 2 files model. s4 have very rich sound, high SQ, will back to it, 2 files can give more potential coz isolate process better than isolate thread, lesser negative affect to sound.
uploaded:
v2.88 1024
v2.88.1 1024
very nice! much room for improvement
2.88.1 feels better. treble better. cleaner micro. better emotion.
2.88 little dirty at micro, i think.
stage seems stable.
Re: lekt player
for 2.87.2, 2.88, 2.88.1, i think the width is stretched left and right. after a while, feels unnatural
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:for 2.87.2, 2.88, 2.88.1, i think the width is stretched left and right. after a while, feels unnatural
and i feel a litte earache although not intense, not strain. maybe sharpness, balance?
uploaded:
v2.88.2 1024
v2.88.3 1024
prefer v2.88.3, small file size, used new method, single thread. but pops in case of onboard sound card.
try them.
Re: lekt player
uploaded:
v2.88.2 1024
v2.88.3 1024
try them.
micro-vibration:
-when sound volume is weak
2.88>2.88.2>2.88.3
-when sound volume is high
2.88.3 seems best
(i misjudged 2.88.1. it strains the sound little bit, so it has false-clean.)
when details of weak volume is needed, 2.88.3 gets unstable in stage. this is reflected in rock when lots of drums happening.
normally, 2.88.3 > 2.88.2
Re: lekt player
i see 2.79.2, 2.4.3, s4, s8 have clean micro-vibration, soundstage is automatically stable.
2.86 is odd one. little-bit dirty, but stage remains stable.
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:i see 2.79.2, 2.4.3, s4, s8 have clean micro-vibration, soundstage is automatically stable.
yes, last versions have something like as bug in code, used some #pragma, and dllimport maybe not optimized for data type of functions parameters. sound a bit terrible now.
