John Dot wrote:This is hell for me,
Just can't run any new MQn version.
Latest working is 2.71 v2 which is the best I heard.
I have tried newest Lekt builds and it's out of the competition. Sorry Lekt.
whats your dac?
which version did you try?
i couldnt get em to work
I'm on Win7 pro, probably that's an issue.
I tried all versions :) I'm following MQn since beginning but 2.71 is most problematic.
I must to upgrade my Win but I don't like metro a lot.
whats your dac?
i meant for lekt player
Easier to get used to win 8.1 than win 8
probably the most likeable windows since win 7
no probs with any version of mqn
sbgk wrote:uploaded the different versions sd = v2 and sb is probably the one with most air/detail
Tried sb and sw and sd, got distortion and slowed down playback.
I have the same problem! Get distortion with the latest sb, sd and sw.
Either with MQN.bat or with mqncontrol 1024. I'm not using any scripts or short-cuts, just the old-fashion way!
is 1024 raw background ok ? does v2 play ok ? are you using 8.1/R2 ?
jkeny wrote:The latest 3 1024 versions don't play on my laptop (Win 8 but not 8.1) but previous 1024s did & all SSE2 versions did.
and using R1, same as win8, all sb, sd and sw work for me.
the goal is 3D/soundstage now?
-all 3 versions need more 3D.
-not sure we are going for multi-focus or single-focus stage. raw background is quite multi-focus.
-need bigger width in soundstage. soundstage is currently muddy in positionings.
