Updated the mess of my last post
cant seem to get the hang of these touch keys at all
no probs:) i've updated mine too
I meant to ask
what you thought of the ppa usb3 card ?
I havent heard one as of yet
what are you powering your pc with at the minute?
is it a standard atx power supply?
nige
nige
i have a thermaltake 520W ps at the moment..
i can say only positive things about PPA usb card (i have last version with silver wire transformer) after my mobo's generic usb2 and usb3 and i'm still giving it a dirty power... result was imediate: improved resolution, more analog timbres. and this is still with dirty atx power to it. in few days i'll get linear 5v1a power and will report back the results.
I had a silent seasonic atx power supply before I went pico + linears
it was good compared to run of the mill atx supplies
The linear pico combination will give a good lift in sq over an atx supply
even to start with one linear 12v gives a great improvement
Im sure youll have a great sounding system when your done
nige
nige
it's a neverending story i guess:) and i'm still enjoying it very much!
i know too well it never ends.minionas wrote:it's a neverending story i guess:) and i'm still enjoying it very much!
![Image](http://farm9.staticflickr.com/8258/8646266008_f931da27f3_z.jpg)
see the two silver colored dials one of them is the voltage
![Image](http://farm8.staticflickr.com/7341/9392485297_6bb6b82eda_c.jpg)
maplin power supply arrangement
![Image](http://farm6.staticflickr.com/5447/9392481585_49b059dffb_c.jpg)
this is the cpu motherboard plug this is what you connect one of the 12v (7 AMP MAPLIN) supplies yellow = +12v black is ground
![Image](http://farm8.staticflickr.com/7291/9392476005_d370b141de_c.jpg)
SEE HERE IS A SHOT OF THE SATA POWER PLUG BUT UNDERNEATH THIS YOU CAN SEE A VOLTAGE REGULATOR WHICH IS NOT NEEDED FOR NEW BUILDS NOR IS A THIRD MAPLIN SUPPLY
AS THE WALL WART LINEAR I LISTED FROM EBAY HAS A ALMOST IDENTICAL SQ AT FAR LESS COST AND SIZE
http://www.ebay.ie/itm/200856094784?ssP ... 1439.l2649
![Image](http://farm4.staticflickr.com/3827/9395235048_54362a2b41_c.jpg)
this is a power sata for ssd connect red wire is the +5v black is ground use +5v linear wall wart here
![Image](http://farm4.staticflickr.com/3703/9392462917_304b1e6811_c.jpg)
![Image](http://farm3.staticflickr.com/2885/9395272062_68a91c9b8c_c.jpg)
this is a 8 pin plug(only used six of them) i used to bring the 3 linear 12v supplies into the pc case, just so i can hit one main switch hit the on button on the pcs and be up and running in no time
![Image](http://farm4.staticflickr.com/3724/9392506457_fc7cef47c9_c.jpg)
![Image](http://farm3.staticflickr.com/2872/9395281320_570d07384b_c.jpg)
![Image](http://farm3.staticflickr.com/2867/9395268114_7cae5717b1_c.jpg)
![Image](http://farm8.staticflickr.com/7294/9395286620_8378dd24d7_c.jpg)
![Image](http://farm8.staticflickr.com/7298/9395291102_a179a7b18c_c.jpg)
![Image](http://farm6.staticflickr.com/5335/9395298038_24af17f877_c.jpg)
thought id frighten yous with a pic of what testing looks like
![Image](http://farm4.staticflickr.com/3800/9395262138_a185cefc9b_c.jpg)
- Ken Moreland
Nice work,Nige. Maplins must be very happy with you :) What current does the motherboard plug draw?
