A turntable, finally?
Re: A turntable, finally?
Bought new in last few months, so I assume recent reissue.
Nerdcave: ...is no more!
Interesting, ta! Don't think my amp can cope with low output MC, which might be one blot.
I can second Ivor's recommendation on Denon DL-103, brilliant cart for the money.
I just checked and the Denon DL103 is a perfect match for your Rega RB330. The only downside is the output is quite low (0.25V) for a moving coil and of course you would have to have moving coil inputs on your amplifier. Something around 0.4V is desirable!
I can highly recommend Denon as well, as I had a Denon DL304 (discontinued) moving coil and it was excellent!
Yeah, thats off to the side a bit alright but it might not have much effect on sonics while playing.
When you say it gets worse as you move towards the centre, to me that is a dead giveaway that the alignment is off. When travel is possible you could bring it here and I can align it for you. You might get someone closer maybe that would be easier.
Unless you go for a phonostage that can take low output MC then you'll need either high output MC or else MM. There's usually a big temptation to push the cantilever to straighten it. That usually ends in disaster.
I wonder if there is too much antiskate pulling it towards the centre?
Whatever you do next think very carefully and absolutely no rushing into it. A MM is the way to go for now for obvious reasons. Which one is entirely up to you. The new Goldring E series and Audio Technica VM's are garnering good reviews. Read the reviews from customers too. Research, research, research.....Stay away from MC's for now until you get to Level 5 ;) Another desirable would be, ahem, the High Output lower priced Hana EH at around what you're willing to spend...Good luck!
Thank you very much for the offer, Fran. If I'm ever allowed go to Kildare again I may indeed take you up on it, not least because a second opinion would be great.Fran wrote: ↑Tue Oct 06, 2020 9:29 pm Yeah, thats off to the side a bit alright but it might not have much effect on sonics while playing.
Meanwhile, let's say that, eh, you got a little bit exasperated at one point and, oh, were indeed tempted to push on the cantilever a little bit and, ummm, really should know better but curiosity killed the cat and all that, and, you know, well, it's like this...
Maybe I'll just take the opportunity to upgrade the cart anyway!
Thanks all for the suggestions, frantically reading reviews now. (Actually, in the course of this research, I've found more than a few people complaining about the Elys cartridge and bad tracking problems. So, you know, maybe it's not ALL down to me...)
It's not all down to you. Those moments are quite common and understandable.Diapason wrote: ↑Wed Oct 07, 2020 11:31 am
.....So, you know, maybe it's not ALL down to me...)
Don't just buy a cartridge on the strength of a good review. The effective mass of a tonearm and the compliance of a cartridge have to be matched. Low mass arm - high compliance cartridge and high mass arm - low compliance cartridge, is the rule of thumb.
