I made a quick research on that tonearm (Jelco SA-13TL1) and it comes out that the problems are mainly due to the tonearm and the way it was mounted on the turntable by the Italian Lenco factory:bod wrote: ↑Wed Dec 11, 2024 11:03 amNo worries. When it comes to alignment, I much prefer Baerwald over Stephenson. Baerwald gives much better performance on the inner grooves for long sides. Inner groove distortion is something I cannot abide.Brutus1968 wrote: ↑Mon Dec 09, 2024 4:26 pmThank you very much, but I should be OK. I may try to experiment with other alignment options and see if I can get an even better result. But me ears are satisfied so far.
Best
https://audiokarma.org/forums/index.php ... gn.983381/
Legends apart, when I use the alignment calculator on Vinyl Engine the null points positions are pretty weird: 44.4 and 92.34cm.
I will repeat the alignment considering those points and keep it that way.
Best
