ULTRASONIC RECORD CLEANER ?
Cyndale
Re: ULTRASONIC RECORD CLEANER ?
Post by Cyndale »
Thanks for the info. I usually only clean secondhand LPs myself. I always play an LP first before deciding if it needs a clean.
I have got tremendous use out of the Nitty Gritty and they have gone out of business in the last couple of months or so. With a bit of cash to spare I was considering upgrading to the Project! I know a guy with has an ultra expensive ultrasonic cleaner, Klaudio I think and he swears by it. The cost is too prohibitive for me. Is the 'BAKU' ultrasonic made in Poland?
Its unapologetically a homemade thing - an ultrasonic bath which sits into a plastic bucket thing, and hardware fixings. The separators between discs are jam pot lids. It all works mind you, but you'd have to be comfortable with that. If you ever want to see mine and have a go of it, no problem if you want to call down here sometime and have a go....
Cyndale
Post by Cyndale »
Thanks for the detailed response. Will check the Project RCM.
sdiesel77
Post by sdiesel77 »
Same as Fran said, if you can accept the DIY look, I am really happy with the cleaning result.
