Plastic CD cases - Free to a good home
For Sale/Wanted
Sloop John B
Re: Plastic CD cases - Free to a good home
Post by Sloop John B »
Gussy Finknottle wrote: Tue Apr 25, 2017 9:04 am Thank you for your reply
I would take as many as i could get.I would use them for replacing the broken cases of cds in charity shops here in Kerry that i help out in.
Apologies for not getting back to you earlier last week but was out of the country for a little while
We'll see can we arrange something, can you PM me of when you might be in Dublin between this and 21st May? I'll try and keep the undamaged ones for you if it can be arranged.
regards,
John
bod
Post by bod »
They might be ok. I think the main problem with those wallet sleeves I was using is that the discs could not "breathe" which probably accelerated the rot (I always had them zipped closed). A little bag of silica may have prevented it, but hindsight is the ultimate as many would agree!!! Hopefully your discs will be ok :-).
Post by james »
Sloop John B wrote: Tue Apr 25, 2017 1:01 pm
so hopefully I won't have the same issues as there is no part of the CD exposed to the air and I'm going to keep them in sealed plastic boxes (when I locate the correct size!).
Thanks for the feedback, none the less.
John
Try the following ..
https://www.amazon.co.uk/d/Storage ... +box
'The really useful box' company makes boxes in various sizes. Eason's sells them and so does B+Q (last time I looked)
shaywhelan
Post by shaywhelan »
I have used these clear plastic stacker boxes, available from Amazon UK, in the recent past https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
Cheaper than the "Really Useful Box" version but, to be honest, not as well designed and a bit bulkier.
Shay
Sloop John B
Well Home store and more came to the rescue with these boxes
They are just the correct size for my CDs stored in the plastic wallets.
.sjb
