Like
Yes
22
100%
No
0
No votes
Total votes: 22
Re: It didn't explode....... YET
nige2000 wrote:
Diapason wrote:Where do you put the CDs in? :)
short answer is to be an amp
long answer is that its a self sustaining reference power supply providing between 0-66 v dc in 3.3v increments
suitable for all things audio:)
I thought you were just intending to use it as your amplifier PS?
Are you thinking of using it in the way highlighted - having taps off each 3.3V to external connections for powering other equipment i.e external connections for 3.3v, 6.6V, 9.9V, etc.?
yes thats the final intention
this build will be an amp which i am excited about,
however even more excited about the possibilities of this ps system of which it would be possible to have a good sounding source/s/dac/amps all in one unit powered by one main power supply system
i have 4 10 secondaries transformers left when i finish this i might consider an all in one jobby
i will likely put a jfet buffer in it when i figure out which suits best, hopefully using the same ps system as ill compare to external battery pack and if it's as good as the battery packs i'll know all is golden
I think I have a spare DCB1 board if you want it....
Fran wrote:I think I have a spare DCB1 board if you want it....
Well ive no need for the power section it might be a bit of a waste
But if youve no use for it it certainly would be useful
no worries...
Impressive build Nige, would be interested to see how they would perform on some large cones like in Darius Speakers.
The instantaneous power available should be serious.
Sligolad wrote:Impressive build Nige, would be interested to see how they would perform on some large cones like in Darius Speakers.
yes i hadn't thought of that
it certainly would be interesting
fast transients are really good with a steep clean leading edge
the speed of the push pull on the cones is unreal when you look close
id nearly consider slowing down the ps with some caps to give the drivers a bit of a breather
im no speaker expert so im guessing that because the larger cone has to do far less travel to move the same amount of air it would be in a better position to deal with the dynamics/speed of the signal from the lifepo4 powered amp?
Ken is chomping at the bit to try that bomb on his speakers. His experience recently has harden his resolve to take risks:)
tony wrote:Ken is chomping at the bit to try that bomb on his speakers. His experience recently has harden his resolve to take risks:)
kinda looks like a bomb or what i think a bomb would look like, like most audio the power supply is the foundation on which to build
and this sure is one crazy power supply
the amp itself is just integrated circuit chips using peter daniels boards
http://www.audiosector.com/lm3875.shtml
which leaves the amp assembly pretty much as simple as signal in signal out and power supply +/- and gnd
the chances of buggering that up is slim
the self sustaining power supply has much much more connections to be made on what essentially is live when your building it
so plenty of excitement and suspense which is the reason for the thread title
i can assure you if a wrong connection was made the batteries would tell you immediately
the power supply section is functionally finished and stable there is a bit of tidying to be done
so if it was going to do anything dramatic it would have pretty much done it by now
id prefer to finish it completely before bringing it anywhere,
did i hear the trio 10's prefered 100w of power?
maybe that was just to have sufficient reserve/capacitance?
What's the power output of your new amp? I don't think the Trio's are hard to drive, although they are reputed to like some power to get going . When your amp is ready bring it down and we'll see.
