The DIYINHK USB to 12S card
Re: The DIYINHK USB to 12S card
I keep looking at your concoction.
I see you are using the LED card and there seems to be some kind of regulator on the other side - but I thought you were using a battery for supply.
You have me baffled with this one.
When you are so inclined I think this is a project worth a map (please).
The INTONA looked interesting until I saw all of those isolators thanks to SLIGOLAD's kindly submission of photography.
Always interested to hear what your supremely experienced ears think of it.
Take care,
Take care,
see the momentary switch and its too red leads
thats all you need to worry about
the rest is related to the usb hub(regen mod) and some other experiments that didnt work out
on boot up u press and hold for 3 secs to complete handshake
theres not too many devices that will take a dose of reverse polarity lifepo4 think of the current
id like to mod an intona but not sure id like to do it enough to pay the money for it and it did prove a little fickle as we couldnt get it to work with my soekris direct bypassing my built in hub
we also failed to get it working on an "anker" battery supply which was disappointing
Needless to say the card was gone as soon as I touched the second lead to the battery.
Smoke was generated immediately along with my berating myself effusively. I had just looked at the battery and somehow, mindlessly, had turned it around. Makes me sick (of myself).
So where are you getting the five volts from? The PC supply?
sometimes i think you cant readrickmcinnis wrote:Needless to say the card was gone as soon as I touched the second lead to the battery.
we momentarily inject 3.3v into the usb5v input for handshake
3.3v is enough to do it
Tried the Intona on the Meitner this evening and with the long red PPA USB cable it would not lock so I stuck one of the shorter Supra cables between the Intona and Meitner and it locks every time now without Regen needed.nige2000 wrote: id like to mod an intona but not sure id like to do it enough to pay the money for it and it did prove a little fickle as we couldnt get it to work with my soekris direct bypassing my built in hub
It is not that I cannot read, it is that sometimes I am not sure what I read is what you meant.
You can write in a shorthand that assumes the reader knows what you know. So when this reader does not know, or I am unsure if that is what you meant, I will ask again! I have my own ingrained assumptions about things so if what you say does not agree with what I think I know I need the statement to be made with conviction!
If you put things as clearly as you did with that post there would be no confusion and, likely, but I know better than to promise, not a second asking of the question.
I did not know that this handshake voltage was not critical.
AS ALWAYS, thanks for the help.
ok i though i wrote it clearerrickmcinnis wrote:It is not that I cannot read, it is that sometimes I am not sure what I read is what you meant.
+3.3v into the usb +5 input marked V+ under the usb b socket
thought we tried the two supras with the intona and soekris bypassing the reclocking hub?Sligolad wrote:Tried the Intona on the Meitner this evening and with the long red PPA USB cable it would not lock so I stuck one of the shorter Supra cables between the Intona and Meitner and it locks every time now without Regen needed.nige2000 wrote: id like to mod an intona but not sure id like to do it enough to pay the money for it and it did prove a little fickle as we couldnt get it to work with my soekris direct bypassing my built in hub
Yea, in Tony's, we tried the Supra cable (short?) instead of the PPA cable (long?) with the Soekris DAC & it still didn't work - seems to be sensitive to signal quality - thinking about it, we probably should have tried the Regen before the Intona just to get a clean 5V supply into the Intona as the 5V injection through the adapter didn't worknige2000 wrote:thought we tried the two supras with the intona and soekris bypassing the reclocking hub?Sligolad wrote:Tried the Intona on the Meitner this evening and with the long red PPA USB cable it would not lock so I stuck one of the shorter Supra cables between the Intona and Meitner and it locks every time now without Regen needed.nige2000 wrote: id like to mod an intona but not sure id like to do it enough to pay the money for it and it did prove a little fickle as we couldnt get it to work with my soekris direct bypassing my built in hub
I really worry for the Asian economies if Rick (and dare I say Nigel) hang up their soldering irons! I do however admire their chutzpah (from a distance). I would never dare.rickmcinnis wrote:Needless to say the card was gone as soon as I touched the second lead to the battery.
