Looking for the highend hifi/AV rack
For Sale/Wanted
Komornick
Re: Looking for the highend hifi/AV rack
Post by Komornick »
Still looking...
MooseTrackz
Post by MooseTrackz »
what do you picture as the ultimate unit your after?
any particular materials that you have your heart set on?
any style that piques your interest?
chief chef
Post by chief chef »
hi is this still for sale ?
Komornick
Post by Komornick »
Still looking.
Komornick
Post by Komornick »
BUMP !!!
Nigel
Post by Nigel »
Hi Fi Rack (2).JPG (18.78 KiB) Viewed 2442 times
Hi Komornick,
I see you're still searching. I have recently sold my higher end kit (lack of use) and my rack is now surplus to requirements. It stands 31 inches high, has 5 shelves which measure 21.5 x 19.5 inches.The gaps between the bottom and next shelf is 8 and the others are all about 5.5 inches. Shelves are black and nicely bevelled. The construction consists of 4 steel legs which run within spacers to define shelf height; each is bolted to give rigidity.
There is some chipping on the leading edge of the bottom shelf and the imprint of equipment feet may be detected on some shelves. I have cleaned the unit but made no attempt at touching up the chips.
I bought the unit from Cloneys about 11 years ago; unfortunately I do not remember the brand. I would hope to get c.€150 for it - about half what I paid. Have tried to insert a photo. If you think you might be interested, send me a PM.
Regards,
Nigel.
Keep Doing The Fun Stuff.
plunkfra
Post by plunkfra »
Hi Komornick,
Ash Design Cosmic 4 AV rack. Width 1100mm; Height 680mm; Depth 560mm. Frame is powder coated acoustic steel with a solid wood (ash) front; shelves are toughened glass. A beautiful piece of furniture. I have PMed you separately with some more details.
Darek
Post by Darek »
If you are interested I can build for you Hi-Fi rack to your specification, It can be build from any available timber for the shelf.
I'm using anodized aluminum profile they can be fill up with quartz sand to eliminate unwonted vibrations.
That one on the pictures is made from oak and I have it at home if you like to see it you are more than welcome.
Size is only limited by available material sheets and your imagination max length of profile 1200mm.
Thank you
Darek
Nigel
Post by Nigel »
Komornick,
E mail and requested photos sent.
Nigel
Komornick
Post by Komornick »
Still looking.
