lekt player
lekt
Re: lekt player
Post by lekt »
i have uploaded lekt.exe1644 v2.2
better method working with RAM.
Re: lekt player
lekt wrote:i have uploaded lekt.exe1644 v2.2
only 1.4 and 1.4.1 work for me.
1.4.1. raw but focus and emotional. able to listen for 1 to 2 mins into crackling distortion non music. need a fix.
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote: only 1.4 and 1.4.1 work for me.
strange. i suspect Data Execution Prevention, if didn't disabled, try
bcdedit.exe /set nx AlwaysOff
uploaded v1.4.2, recompiled, hope this problem will be fixed. on my laptop win8 sound very good, mellow/strong/power, although this version read data from file to buffer.
Re: lekt player
Welcome aboard Lekt. As per Pearse MQn a bit like Lord of the rings has the eye at the moment. Will get to try out your player at some point.
Hope yourself and sbgk share all insights with each other and we all benefit.
lekt
Re: lekt player
Post by lekt »
tony wrote:Welcome aboard Lekt. As per Pearse MQn a bit like Lord of the rings has the eye at the moment. Will get to try out your player at some point.
Welcome, tony. currently lekt player have problem with some soundcards, v1.4 works on JC's PC.
i haven't tested for PCIs or USB DAC. i'll try more.
if it have issue with .dll file, need install Visual C++ Redistributable for Visual Studio 2012 Update 3 (vcredist_x86.exe).
Best regards.
lekt
Re: lekt player
Post by lekt »
"... lekt player have problem with some soundcards ..."
issues with soundcard incompatible have fixed.
i have uploaded 4 file for 4 buffer sizes into TEST_SOUNDCARD folder:
lekt.exe 06 test 160, lekt.exe 07 test 256, lekt.exe 08 test 512, lekt.exe 09 test 1024.
https://drive.google.com/folderview?id= ... sp=sharing
try these for testing. waiting for your comments.
Thanks & Best regards.
lekt
Re: lekt player
Post by lekt »
uploaded lekt.exe1644 v2.4.2 256 . Try it and enjoy.
lekt
Re: lekt player
Post by lekt »
have uploaded some versions lekt.exe1644 v2.4.3 xxx with different buffer sizes.
there have builded by same code. try it.
lekt
Re: lekt player
Post by lekt »
uploaded v2.5.1 1024 , v2.5.2 1024
bass improved with better vibartion, soundstage keeped. mellow versions will be done later. soundstage more important that i try keep it in all versions.
try and enjoy.
lekt
Re: lekt player
Post by lekt »
have upload version lekt.exe1644 v1.6 readfile. i used interesting method file reading. try it.
