Is isopropanol the same as isopropyl alchohol Fran?Fran wrote:My formula:
75% RO water
25% pure isopropanol (propan-2-ol)
2mL of rinse aid per litre of this mix
I use wet/vac cleaner which cleans up about 90% of records. I suspect that an enzyme based one would do another 5%, and that the last few are beyond cleaning.....
Isopropanol won't damage your records.
How and what do you use to clean your records?
Re: How and what do you use to clean your records?
Yes.
Just be aware that most of that sold in chemists etc is actually 75% iso with water and fragrance etc. Hard to get the pure stuff.
Thanks for clearing that up :)Fran wrote:Yes.
I have used knosti disco antistat. Have had good results although may try a different liquid formula as it can leave gunge on the vinyl.
I have a reverse osmosis water filter in the kitchen so can use that for rinsing but may lose antistatic properties of knosti liquid.
