I think the background setting doesn't improve things, should remove it from the readme file.wushuliu wrote:Same registry path as changing Background from False to True listed in the Readme. The clock rate is right above it. Guessing you just modify to one of the numbers mentioned. It would be good if someone could clarify that part.minionas wrote:Hi,jesuscheung wrote:sbgk. try a 4 digits clockrate. 4644 instead of 46440. no need of 6 digits never sounded good.
Could you please share a registry path to clockrate variable?
by reducing it by a factor of 10 you're making something work 10 times as often, are you sure it's an improvement ?
Any comments about the latest version ?
Taggart should have some good news about his loader program soon. I tried it last night and it's very good/useful.
