- goon-heaven
I know what you mean about the sse2's
But do you prefer it over the sse4's[/quote]
yes.[/quote]
+1 (at least on 2.64 sse2)
yes.[/quote]
Out of interest, what lengths have people gone to in order to rule out expectation bias or placebo etc?
Let's say set up two laptops with different MQN versions installed. Perhaps one with filenames changed and and the other unchanged also. Then play a track for someone but without them knowing which version/config is playing.
If the improvements are as big people say they are then surely they can be picked out with consistancy in the above scenario?
(and please dont mention horseshit about being under pressure in an unsighted test)
yes.[/quote]goon-heaven wrote:I know what you mean about the sse2's
+1 (at least on 2.64 sse2)[/quote]
sorry. i meant yes, i prefer sse4.. haha
don't you feel SSE4 each note of a piece of music finishes with more details in the air? sound last longer in the air. that's why i meant i think.Clive wrote:My turn for a question. The spread / poison gas thing with SSE4, is this a lack of focus and does SSE2 give more central focus?jesuscheung wrote: 2.64 sse2 v2, 2.64 sse2 v3
-both sound like other previous sse2 versions. sound don't spread as much as sse4. sse4's sound is like poison gas, it spreads everywhere.
-both sound good. top all other sse2.
-because sse2 sounds simpler. feels cleaner and clearer. feels more organized.
no need to blind test! just do quick 1 2 comparison. there are 200 versions! who can remember so much. only 3 or 4 versions i can tell from blind test.DaveF wrote:Out of interest, what lengths have people gone to in order to rule out expectation bias or placebo etc?
jesuscheung, can you tell me which CPU and motherboard you use?
Also which OS are you using?
I am curious?
thanks
Erin
I am curious?
thanks
Erin
Buy locally.
Build locally.
Grow locally.
Share locally.
Buy locally.
Build locally.
Grow locally.
Share locally.
I've performed one blind test accidentally and one on purpose. The on purpose one was with 4 people, individually. I chose versions of MQn which I found to be sound quite different. Their blind test results were the same as my sighted ones. There are many versions of MQn which sound more alike and so are harder to tell apart, these would be a tougher blind test. I refer you back to JK's comment about the Limbic System, blind tests typically make us avoid using the Limbic System so we end up not fully listening, just being analytical (mostly for FR and detail) but missing the point to music.DaveF wrote:Out of interest, what lengths have people gone to in order to rule out expectation bias or placebo etc?
The rate of change with MQn makes it non-viable to blind test and I don't care for blind testing anyway.
3770K.erin wrote:jesuscheung, can you tell me which CPU and motherboard you use?
I am curious?
thanks
Erin
z77 asus board.
i use all 7, 2012, and 2012 R2.
JC
"sse4's sound is like poison gas, it spreads everywhere"
is probably not the best way to describe something you like ;)
thats why i asked whether you preferred sse2 or sse4
im curious what Avx would sound like (Dave calm down were not hurting any one)
JC is very thorough checks all versions, settings os's etc etc mad man
i get difficult just to test the versions
haha. i just thought poison gas has the best spreadability. it is made to kill.nige2000 wrote:JC
i find OS tweaks very difficult. minimalist doesn't equal best SQ.
many easy 1 click optimization scripts people use contain harmful tweaks. most people don't realize.
bios tweaks is much easier to perfect.
