install:Clive101 wrote: My CPU is an Intel Core i5 2500T which is quad core SSE4 and running Windows 8.1 64 bit. My DAC is a dCS Debussy connected via on board USB. It doesn't have any drivers as it uses the Mirosoft USB driver. I have had this working with JPLAY5.1 and JRIVER Kernel streaming and JRIVER via WSAPI all fine.
In Windows I can see the dCS as a sound device and it plays fine and have tested it via JRiver and it plays in all modes (ie Kernel streaming, WSAPI, WAV Out etc)
Really appreciate any help or advice on what to try / test to get MQN playing.
Regards
Clive
1. download MQn.bat, paste.exe, a version of mqncontrol.exe, a version of mqnplay.exe.
2. put them all in one folder.
3. if you download mqncontrol.exe no affinity v2, make sure rename it as mqncontrol.exe.
4. if you down mqnplay.exe 2.60 sse4 intel, make sure rename it as mqnplay.exe
play a 16/44100 file, must be wav.
1. ctrl+c to copy the music file.
2. double click MQn.bat
3. music should come out.
https://drive.google.com/folderview?id= ... Utbm8#list
