Cable for Telephone Extension
Post by james »
I want to buy cable to run an extension for my telephone from the hall to upstairs. Previously I could get suitable wire in Peats or Maplins but both are now closed. Can anyone suggest a shop (physical or online) where I can purchase same. I will have to run it on the surface so I want something fairly inconspicuous.
Thanks.
Re: Cable for Telephone Extension
Jaomes, cablemonkey or you can try elara but not sure if they can do to size.
Hi James, my ex company used CPC for cables, etc. I always found them to give a quick service and competitively priced.
https://cpcireland.farnell.com/
I'm pretty sure the first couple of times we used them I just paid by card without opening an account.
Post by james »
Thanks to both of you, Will investigate.
James
