after much tinkering got it figured out
well whats the point ?
well its to remove the switching dc converter which is sending noise into the system, there also may be a better esr to the power as bass response and weight is much improved as well as the reduced noise floor
CONFIRMED WORKING MOBOS
gigabyte
h97m d3h
z97m d3h
MSI B85M G43
Z87M G43
H81M-P32
H81M-P33
asus
h81i-plus
well the whole system is based on this
all is colour coded red is 5v purble is 5v standby which powers the on switch
yellow is 12v orange is 3.3v and black is gnd
ive merged all the 12's 5'5 and 3.3's and ground as seen in the pic with a solder joint
why?
because if you continuity test all the 12's 5's 3.3's and gnd on the 24 pin socket they have very little or no resistance,
so i couldn't see why any other method would be better
gnd routing is one of the most interesting aspects of the build (the way different methods effect sq)
one of the best metods is to have a star ground point to which the 24 pin, 4pin,ssd,usb card etc etc gnds connect to somethimg like a copper bar like aleg mentions below would be perfect
linear power supply:
the minimum recommendation would be three separate rails 12, 5, 3.3v each with their own transformer, bridge rectifier and regulator
additional benefit can be achieved by having additional rails with the same method an additional 12v solely for the cpu leaving one dedicated for the 12v on the 24pin
additional 5v rails for ssd, usb card one each is optimal but im a fan of batteries especially for these extremely sensitive devices
battery solutions:
long and the short of it is that lifepo4 seems to be the best where noise floor is at its lowest, bass definition and weight are at its best which again is probably due to low esr
so can i tell difference between lead acid, nimh and lifepo4 ?
i believe i can, although all of them is an improvement over the simple linear supplies
ill be back later.....
