Randy,randytsuch wrote:From what I read this morning, it is harder to boot from windows 7 into a newer windows. There is extra "stuff" you need to do. If I upgrade to windows 10, it would probably work.
I can't confirm that. My first steps booting into VHD in my way booting into RAM have been on my productive W7 PC. R2 is still on there and working. I would guess you have an UEFI Bios? That causes a lot of trouble. In this case check the latest version of BCDeasy, it says that it is able to handle UEFI Bios now. I have not tested that because I have no such issues in my systems.
That's sure not the normal R2. I have started with 13 GB VHD just to be on the save side. I can confirm that the installation works with 10GB safely, minimum without any compacting, which risks a lot of single system dependent issues, is 8GB.randytsuch wrote:The other thing is my vhd is larger than expected, if I remember correctly it's around 13 G.
Finally, instead of W10 I would strongly recommend to go with Server 2016 TP4, you will be surprised. You would need a minimum of 10GB VHD which leaves a bit less than 1 GB free. It works pretty well in RAM the same way as R2 does.
Enjoy the music ;)
Thomas
